Discuss
Baffle Kit Replacement Procedure? (WP Duet)
 in
Washer Repair
My baffles arrive today so I plan on installing them tomorrow using Dave's directions. I'll be sure to post results
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Baffle Kit Replacement Procedure? (WP Duet)
  #11 (permalink)
Old 10-10-2007, 07:34 AM
Junior Member
Leonard is on a distinguished road
Default
My baffles arrive today so I plan on installing them tomorrow using Dave's directions. I'll be sure to post results (and can get pictures if anyone thinks they would be useful for future posters).
Lynn did you get yours installed yet?
--Larry
Ads By Google
  #12 (permalink)
Old 10-11-2007, 08:17 AM
Junior Member
Default
Did not take pictures, but the install went VERY smoothly using Dave's instructions. I replaced all the baffles (and both had some broken tabs) but they were quite hard to get off of the drum. None of them had the screws installed.
Total install time 30 mins and a good bit of that was trying to get the washer out where I could work on it.
  #13 (permalink)
Old 11-08-2007, 04:51 PM
Junior Member
robmints is on a distinguished road
Default
Thanks everybody. This must be a very common problem. Thanks for the fix Dave! I was about to do what Leonard was about to do.
  #14 (permalink)
Old 03-07-2008, 03:43 PM
Junior Member
cdmcdonell is on a distinguished road
Default Thank you
Thank you for saving our marriage. I won't mention which one was right just that the post was correct
  #15 (permalink)
Old 04-07-2008, 09:27 AM
Junior Member
rshaw is on a distinguished road
Default
Thank you everyone. My baffles look different as well. Must have done a design change. Looks like the new one's tabs are in the same location. Leonard, do they behave differently than the old one's or can you tell a difference? And yes the scree hole in my old baffles never had a screw in it. Talk about lazy work at the factory.
  #16 (permalink)
Old 01-07-2010, 09:56 PM
Junior Member
rdd98103 is on a distinguished road
Default Spot On!
Dave (dland): Your post was exactly the identification of the issue and the exact steps to fix it, including the missing retaining screws. Just finished the whole repair in about 15 minutes. The only additional step I had to take was to use a block of wood and a 5lb. mallet to punch the two remaining baffles loose so I could replace them. I took your step #6 seriously and used a magnetic phillips screwdriver to get the screws in place. The new baffles look a little different, but they only go in one direction, which is with the high part at the back of the drum. I'm sure that would have been a $350 service call. The hardest part was moving the dryer that was stacked on top.
Thanks again!
Quote:
Originally Posted by dland View Post
Lynn "skysentinel",
If you have not already finished this repair, here's good news: it's EASY. Go ahead and order those parts. Get the kit with all three baffles -- its likely that the plastic tabs on more than one of them have been damaged, because Whirlpool apparently never installed the retaining screws that hold the baffles in place. It appears to be a common problem.
1) Remove the three screws on the back of the washer for the lid.
2) Remove the lid.
3) A black rubber hose enters the outer drum top and center near the front. Gently remove it from the drum.
4) Through the resulting hole, you can reach the exact spot for inserting the retaining screws for the baffles.
5) One by one, replace the baffles (they drop into place, then need a little force to slide them forward into place) and rotate the inner drum so that the retaining screw hole is visible below the opening in the top of the outer drum.
6) (Without dropping the screws into the space between the drums like I did ), install the screws to retain the baffles.
7) Repeat for the other two.
8) Replace the hose and the lid and its screws and rest assured that you did something that even the Whirlpool assemblers didn't do: install the baffle retaining screws.
Dave Land
  #17 (permalink)
Old 03-06-2010, 04:44 AM
Junior Member
sihoward is on a distinguished road
Thumbs up Thank you!
Lynn "skysentinel",
2) Remove the lid.
Dave Land
Friday night discovered broken baffle, going out of town on Monday morning, wife is hysterical. Now if I can find the part today everything will be back to normal. Many thanks to pioneers like you that skin their knuckles before anyone else and share the experience.
Scott
  #18 (permalink)
Old 10-21-2011, 12:30 PM
Junior Member
Nassau1969 is on a distinguished road
Thumbs up skysentinel (Dave Land) is the man.
Dave right on the money is was a 15 minute fix that looked as if it was going to be a nightmare job, I would have took a sawzal to this thing if it wasn't for you, super thanks.
2) Remove the lid.
Dave Land[/quote]
  #19 (permalink)
Old 04-02-2012, 03:47 PM
Junior Member
dbinns is on a distinguished road
Default Thanks For the Help!!
I concur with Nassau1969 - with your instructions it was child's play.
One must wonder why the people at Whirlpool did not figure out the correct part configuration in the first place, and then, having designed it with retaining screw holes, decided NOT to put them in. Reminds me of ALL THE DESIGN FAULTS OF MY NISSAN MURANO - but don't get me started.
Thanks so much for taking the time to provide this easy, 15 minute fix.
Doug
Lynn "skysentinel",
2) Remove the lid.
Dave Land
  #20 (permalink)
Old 09-25-2012, 11:02 AM
Junior Member
y2kxmaskids is on a distinguished road
Question Dropping the screws...
So if I drop the screws, what do I do? More specifically, how do I retrieve the broken plastic tabs that came off the broken baffle? My washer sounds like there is a loose quarter or dime in it when it spins. I wonder if it is the old screw or the plastic tabs.
Thanks in advance for help,
Tanya
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
How To Replace A Baffle-Whirlpool Duet Washer gllooman Washer Repair 6 05-23-2010 10:54 AM
Maytag Neptune Washer baffle replacement BHcub Washer Repair 1 02-13-2010 08:48 PM
Kenmore Elite HE3 Gas Dryer Rubber Switch Replacement Procedure eddy123 Dryer Repair 3 11-16-2008 03:53 PM
Maytag Dryer Baffle Replacement Steveblock1 Dryer Repair 1 10-16-2008 12:18 PM
Baffle replacement Amatuer Dryer Repair 0 01-05-2008 09:57 AM
