unable to adjust water level..I accidentally turned the knob too far past low now the knob will not turn to any other water level Thank you for your time
I cannot find any info using the given model number. Kenmore numbers are usually 3 digits, a dot and the 6 or 7 more digits.
If this is a non USA model then I would not be able to find the unit.
Sounds like you need a new water level switch. |
THIS FORUM IS DEAD!!!!!!! |
