I am currently getting the OE error on the display. It appears that the water that initially fills during the wash cycle doesn't stop. Then, it displays the OE error (Overflow Error?). I can see the water level in the tub get pretty high. Even when I hit the power off button, the water continues to flow. I have to manually shut the water valve off. Obviously, the wash cycle didn't complete.
I then proceed to manually select the rinse/spin mode. I can hear the pump drain the water and everything proceeds normally (water inserts, drains and spins). I think this rules out the water level sensor and the water valve (closing when complete)?
I can't seem to find the solution to this issue. Does anyone have any insight on the solution?
Thank you in advance,
-David
