| » Something hitting the drum when it turns |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: GBVH6260FWW Brand: GE Age: 1 - 5 years
Hi there, I just wanted to know if anybody knows how to get inside this front loader machine. When ever the tub turns it is hitting something hard (sounds like it could be a pen) and it is on the outside of the tub. I have tried to look thru the little holes to see if i can see it but no luck. So I thought I would try to get to the outside of the tub, but I cant figure out how. If anybody knows any tricks to figure this out please help me.
Thank you Janjan |
These links should help you take it apart....
Frigidaire, White Westinghouse, Magic Chef, Maytag Performa Dryers, common repair info, no heat, noises, how to take apart
__________________
-Serving North Central Texas and Southern Oklahoma since 1978. www.samsservicesenter.com |
You probably have one of the spin basket support struts rusted off the basket and hitting the tub, eventually it might poke a hole in the tub. Only way to confirm is to pull tub and remove spin basket, a rather labor intensive job.
One idea is to remove drain boot and shine a lite in there and see if you see anything. Please post results.
__________________
| Display Modes | |
| Noise and Drum rocking | momdannie2356 | Dryer Repair | 1 | 10-04-2007 03:04 AM |
| Dryer drum won't turn | tlathan | Dryer Repair | 1 | 08-15-2007 04:12 PM |
| cannot put drum belt back on tight | frank | Dryer Repair | 1 | 08-10-2007 08:37 PM |
| Only 1 fan speed / Unit turns itself off | KenK | Heating, Ventilation, and Air Conditioning (HVAC) | 0 | 08-09-2007 08:25 AM |
| drum will not spin | maria camacho | Dryer Repair | 1 | 07-20-2007 08:56 PM |
