Discuss
GE Washer not draining or spinning, but will agitate and fill
 in
Washer Repair
A couple days ago, my son did a load of laundry and washed a pillow. Since then, the washer will
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE Washer not draining or spinning, but will agitate and fill
  #1 (permalink)
Old 11-22-2010, 10:04 AM
Junior Member
jcsaxx is on a distinguished road
Default FIXED: GE Washer not draining or spinning, but will agitate and fill
Brand: -brand-   Age: Less than 1 year
A couple days ago, my son did a load of laundry and washed a pillow. Since then, the washer will not drain or spin. The washer will still agitate and will fill with water. All the machine does after agitating is, I hear a clicking noise of the timer.
When agitating the motor moves the belt, so that should mean both the belt and motor are good, right???
We have been finding parts of the pillow stuffing around the washing "bowl", but not inside at all. We did take off the outer hose and the water all drained out, but didn't see of the pillow stuffing come out. I'm guessing the problem has to be related to washing the pillow, because of the timing of the machine messing up right afterwards.
So we are stuck going to the laundry mat until we figure this out.
Please help. I don't have anything to check the voltage or anything like that. I have tried the "trick" of unplugging power for 1 minute, then plugging it in, then opening and shutting the lid 6 times in 30 seconds.
MODEL #: wbsb3140daww
Last edited by jcsaxx : 11-28-2010 at 12:47 PM. Reason: FIXED THE PROBLEM: Pump was clogged...
  #2 (permalink)
Old 11-22-2010, 10:07 AM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
What's the model number?
  #3 (permalink)
Old 11-22-2010, 10:23 AM
Junior Member
Default
Quote:
wbsb3140daww
  #4 (permalink)
Old 11-22-2010, 10:37 AM
Senior Expert
APP Volunteer
Default
It sounds like you have a clogged pump. If it is clear,you may have a bad motor or a broken transmission. I don't have any experience with the "clutchless" motor, but if it follows tradition, the transmission is the culprit.
Part number: AP3160348
Part number: AP2046402
Part number: AP3205861
  #5 (permalink)
Old 11-22-2010, 10:54 AM
Junior Member
Default
Pardon the question, but if it was the agitator coupling, would the machine NOT agitate at all?
Please explain if you can.
  #6 (permalink)
Old 11-22-2010, 11:36 AM
Senior Expert
APP Volunteer
Default
EXPLANATION: That post was edited out.
  #7 (permalink)
Old 11-22-2010, 12:03 PM
Junior Member
Default
So if the pump is clogged (won't know until I figure out how to take it apart), the motor won't turn the belt at all, right??? I have no idea what I'm doing, so pardon all the questions. Want to narrow it down as much as possible.
Heading to work.
Thanks for your help.
  #8 (permalink)
Old 11-22-2010, 01:08 PM
Senior Expert
APP Volunteer
Default
Your pump is electric. It's located in the cabinet toward the back right. You'll be able to identify the component by the drain hoses attached to it. A quick way to check to see if it's clogged is to take the drain hose out of the stand pipe and lower it to a level below that of the water in the tub. If water trickles out, or no flow at all, you'll likely have to replace it. This isn't 100% reliable, as water can possibly flow through the pump, and still the impeller can be clogged.
Here's a parts breakdown that shows the general construction of your machine. To open the cabinet, notice the spring clips about 4 inches from each front top corner (the machine top; not the console). While lifting each respective corner, push in against the clip with a flat tool (like a putty knife) until that corner releases. This will expose the screws that hold the front panel in place.
Cabinet, cover & front panel replacement parts for General Electric WBSR3140DAWW Washer | AppliancePartsPros.com
  #9 (permalink)
Old 11-28-2010, 12:45 PM
Junior Member
Default Fixed...
So the problem was that part of the pillow stuffing was clogging the pump. Pulled out the stuffing and now the washer is working. So far, testing is going very good. It's draining and spinning.
  #10 (permalink)
Old 11-28-2010, 06:17 PM
Senior Expert
APP Volunteer
Default
Great to hear you didn't need parts...Well done!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer not spinning and draining Slick Rick Washer Repair 5 08-03-2010 08:48 AM
GE washer draining but not spinning fantasy6 Washer Repair 1 06-27-2010 07:56 AM
Washer Spinning, Not Draining nchokie Washer Repair 1 11-13-2009 05:27 PM
HELP! Washer not spinning/draining but will agitate jeffsji Washer Repair 1 07-31-2009 06:10 PM
GE Washer: Not spinning or draining Vonnie2 Washer Repair 0 11-10-2007 09:54 PM
