Discuss
Roper washer won't stop filling with water
 in
Washer Repair
My Roper washer now won't stop filling up!! I can unlug the unit and it keeps filling. I've tried letting
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Roper washer won't stop filling with water
  #1 (permalink)
Old 11-11-2008, 11:57 AM
Junior Member
jeffct is on a distinguished road
Default Roper washer won't stop filling with water
Model Number: RAS6233KQ1   Brand: Roper   Age: 1 - 5 years
My Roper washer now won't stop filling up!! I can unlug the unit and it keeps filling. I've tried letting it run through its cycle but it still doesn't stop. The only thing I can do is to manually put it into the "spin" mode, turn off the water supply and let it drain. I did notice that only cold water is filling the tub when I unplug the unit. If the unit is plugged in and in the start mode, the water is whatever I selected it to be on the temperature button.
Please someone help.
Thank you.
Related Models
Roper RAS6233KQ1 AUTOMATIC WASHER
Roper RAS6233KQ2 AUTOMATIC WASHER
Roper RAS6233PQ0 AUTOMATIC WASHER
Roper RAS6233PQ1 AUTOMATIC WASHER
Roper RAS6233PQ3 AUTOMATIC WASHER
Roper RAS6233RQ0 AUTOMATIC WASHER
Roper RAS7133KQ0 WASHER
Roper RAS7133KQ1 AUTOMATIC WASHER
Roper RAS7133PQ0 AUTOMATIC WASHER
Roper RAS7133PQ1 AUTOMATIC WASHER
Roper RAS7133RQ0 AUTOMATIC WASHER
Roper RAS7133RQ1 AUTOMATIC WASHER
Roper RAS7133RQ3 AUTOMATIC WASHER
Roper RAS7133RQ4 AUTOMATIC WASHER
Roper RAS7233JQ0 WASHER
Roper RAS7233KQ0 WASHER
Roper RAS8244KQ0 WASHER
Roper RAS8244KQ1 AUTOMATIC WASHER
Roper RAS8244KQ2 AUTOMATIC WASHER
Roper RAS8244LQ0 AUTOMATIC WASHER
Roper RAS8244LQ1 AUTOMATIC WASHER
Roper RAS8245EN0 DIRECT DRIVE WASHER
Roper RAS8245EN1 DIRECT-DRIVE WASHER
Roper RAS8245EQ0 DIRECT DRIVE WASHER
Roper RAS8245EQ1 DIRECT-DRIVE WASHER
Roper RAS8245EW0 DIRECT DRIVE WASHER
Roper RAS8245EW1 DIRECT-DRIVE WASHER
Roper RAS8333PQ0 AUTOMATIC WASHER
Roper RAS8333PQ1 AUTOMATIC WASHER
Roper RAS8333RQ0 AUTOMATIC WASHER
Roper RAS8333RQ1 AUTOMATIC WASHER
Roper RAS8333RQ3 AUTOMATIC WASHER
Roper RAS8333RQ4 AUTOMATIC WASHER
Roper RAS8445JQ0 WASHER
Roper RAS8445KQ0 WASHER
Maytag RAX1000AXW MISC / ACCESSORY
Maytag RAX1000CXB MISC / ACCESSORY
Maytag RAX2000AXW MISC / ACCESSORY
Maytag RAX2000CXB MISC / ACCESSORY
Maytag RAX3000DXX MISC / ACCESSORY
Maytag RAX33 MISC / ACCESSORY
Maytag RAX3300CXX MISC / ACCESSORY
Maytag RAX34 MISC / ACCESSORY
Maytag RAX36 MISC / ACCESSORY
Maytag RAX3600CXX MISC / ACCESSORY
Roper RAX4232JQ0 WASHER
Roper RAX4232KQ0 WASHER
Roper RAX4232KQ1 AUTOMATIC WASHER
Roper RAX4232PQ0 AUTOMATIC WASHER
Roper RAX4232PQ1 AUTOMATIC WASHER
Roper RAX4232RQ0 AUTOMATIC WASHER
Roper RAX4232RQ1 AUTOMATIC WASHER
Roper RAX4232RQ3 AUTOMATIC WASHER
Roper RAX4232RQ4 AUTOMATIC WASHER
Roper RAX4233PQ0 AUTOMATIC WASHER
Maytag RAX5000AXB MISC / ACCESSORY
Maytag RAX5000CXB MISC / ACCESSORY
Maytag RAX5100AXB MISC / ACCESSORY
Whirlpool RAX5133AG0
Whirlpool RAX5133AL0
Roper RAX5133AL1 AUTOMATIC WASHER
Roper RAX5133AW0 Washers*
Maytag RAX5200AXB MISC / ACCESSORY
Maytag RAX5200CXB MISC / ACCESSORY
Maytag RAX5300AXB MISC / ACCESSORY
Maytag RAX5400AXB MISC / ACCESSORY
Maytag RAX5500AXB MISC / ACCESSORY
Maytag RAX5500CXB MISC / ACCESSORY
Maytag RAX5600AXB MISC / ACCESSORY
Maytag RAX5700AXB MISC / ACCESSORY
Maytag RAX5700CXB MISC / ACCESSORY
Whirlpool RAX6144EN0
Whirlpool RAX6144EN1
Whirlpool RAX6144EQ0
Whirlpool RAX6144EQ1
Whirlpool RAX6144EW0
Whirlpool RAX6144EW1
Roper RAX7244EN0 WASHER
Roper RAX7244EN1 WASHER
Roper RAX7244EQ0 WASHER
Roper RAX7244EQ1 WASHER
Roper RAX7244EW0 WASHER
Roper RAX7244EW1 WASHER
Roper RAX7244JQ0 WASHER
Roper RAX7244KQ0 WASHER
Roper RAX7244KQ1 AUTOMATIC WASHER
Roper RAX7244KQ2 AUTOMATIC WASHER
Roper RAX7244PQ0 AUTOMATIC WASHER
Roper RAX7244PQ1 AUTOMATIC WASHER
Whirlpool RAX7245AG0
Whirlpool RAX7245AL0
Roper RAX7245AW0 Washers*
Roper RAX7245BL1 AUTOMATIC WASHER
Roper RAX7245BQ1 AUTOMATIC WASHER
Roper RAX7245BW0 DIRECT-DRIVE AUTOMATIC WASHER
Roper RAX7245BW1 AUTOMATIC WASHER
Roper RAX7245JQ0 WASHER
Roper RAX7245KQ0 WASHER
Roper RAX7245KQ1 AUTOMATIC WASHER
Whirlpool RB1000XKW0 ELECTRIC BUILT-IN OVEN
Whirlpool RB1000XKW1 ELECTRIC BUILT-IN OVEN
Whirlpool RB1000XKW2 ELECTRIC BUILT-IN OVEN
Whirlpool RB1000XVW0 ELECTRIC BUILT-IN OVEN
Whirlpool RB1000XVW2 ELECTRIC BUILT-IN OVEN
Whirlpool RB1000XVW3 ELECTRIC BUILT-IN OVEN
Whirlpool RB1005XYN2 24" ELECTRIC BUILT-IN STANDARD CLEAN OVEN
Whirlpool RB1005XYN3 ELECTRIC BUILT-IN OVEN
Whirlpool RB1005XYN5 24" ELECTRIC OVEN
Whirlpool RB1005XYW0 ELECTRIC BUILT-IN OVEN
Whirlpool RB1005XYW2 24" ELECTRIC BUILT-IN STANDARD CLEAN OVEN
Whirlpool RB1005XYW3 ELECTRIC BUILT-IN OVEN
Whirlpool RB1005XYW5 24" ELECTRIC OVEN
Whirlpool RB100PXK-0 24" ELECTRIC BUILT-IN OVEN
Whirlpool RB100PXK0
Whirlpool RB100PXK1 ELECTRIC BUILT-IN OVEN
Whirlpool RB100PXK2 ELECTRIC BUILT-IN OVEN
Whirlpool RB100PXV0 ELECTRIC BUILT-IN OVEN
Whirlpool RB100PXV2 ELECTRIC BUILT-IN OVEN
Whirlpool RB100PXV3 ELECTRIC BUILT-IN OVEN
Whirlpool RB100PXYB0 ELECTRIC BUILT-IN OVEN
  #2 (permalink)
Old 11-11-2008, 12:46 PM
abadfish66's Avatar
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
You need a new water valve---->AP3094541
__________________
  #3 (permalink)
Old 11-11-2008, 12:51 PM
Junior Member
Default How do I replace it?
I see where the intake valve is located on the back where the water lines come in. How do I go about replacing it?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer won't stop filling with water Shayna Washer Repair 2 02-11-2010 03:57 PM
washer won't stop filling with water oerck157 Washer Repair 2 06-04-2009 11:01 AM
crosley washer will not stop filling water to tub ltsc Washer Repair 0 07-08-2008 03:02 PM
amana washer keeps filling with water. won't stop bubaski Washer Repair 0 06-15-2008 02:14 PM
Admiral washer won't stop filling up with water! imcrazy73 Washer Repair 1 04-07-2008 07:14 PM
