| » Door switch/error code E41 |
Model Number: LTF2940ES2 Brand: Frigidaire Age: 1 - 5 years
Hello all,
I have a Frigidaire LTF2940ES2 front load that has a door lock code E41. I replaced the door switch in the last month and all was well, but apparently its bad again. Is there anything that could be taking this switch out?? $80 a month is going to get expensive!! Ads By Google Related Models |
Replacement parts for FRIGIDAIRE LTF2940ES2 Frigidaire/washer | AppliancePartsPros.com Here is the tech sheet which you may have http://manuals.frigidaire.com/prodin...er/1345420.pdf And here is a manual which should help check the switch assembly. http://frigidaireservicetips.com/pdf...isWasherSM.pdf Hard to see the door switch being blown by something else. Could ba a bad connection somewhere. There may be a bad connection on the control board or a bad solder loint.
__________________
This thread is helpful as my washer is stuck on the E41 door lock error. I'd like to see if there is a loose connection or if I need to purchase a new door lock assembly, but I am embarrassed to say that I don't know how to find the control board. Do I pull off the front LED Display to reveal a circuit board? I have looked over every manual I can find... Thanks!
| Display Modes | |
| F9 error, need help replacing door latch switch | jcburns | Oven Repair (including Ranges and Cooktops) | 0 | 07-15-2010 09:26 AM |
| Frigidaire Door Lock and F9 error code | chispaluz | Oven Repair (including Ranges and Cooktops) | 1 | 07-10-2010 12:03 PM |
| Error code-door lock | Ellay | Washer Repair | 5 | 08-11-2009 01:37 PM |
| error code E1 F5 door lock? | sholmer963@aol.com | Oven Repair (including Ranges and Cooktops) | 3 | 01-02-2009 05:26 AM |
| Door latch error code | KEVMC | Oven Repair (including Ranges and Cooktops) | 0 | 12-26-2008 06:52 PM |
