| » Door Boot Seal/Door Diaphragm |
Model Number: MAH8700AWW Brand: Maytag Age: 1 - 5 years
Hello: I noticed water leaking from my washer and also noticed that the lip at the bottom of the boot is missing a small piece so I purchased the part; now I need some direction as to how to replace it. I have been looking for repair manuals to no avail. Can you please provide me with the necessary book/pages to replace this part?
Thanks a bunch! Ads By Google Related Models |
Quote:
Octavio, Here are excerpts from the Service Manual for your unit, in reference to the boot access and removal procedure. It'll take some time, but you'll be able to handle it, and be up and running in no time. Good Luck, Top Removal 1. Disconnect power supply to unit. 2. Remove 2 10mm screws from washer back 3. Slide Top Cover towards the rear to clear the screw head from flange on the bottom side of the Top Cover Dispenser Removal 1. Disconnect power supply to unit. 2. Depress the release tab and slide drawer from washer Console Removal 1. Disconnect power supply to unit. 2. Remove Top Cover. 3. Remove Dispenser Drawer. 4. Remove five screws attaching Console 5. Roll Console down and lift away from washer. 6. Remove Reactor wire harness from wire clip. 7. Remove Reactor wire harness connector from the PCB Board. 8. Remove five screws from PCB Housing to access the LED Circuit Board Front Panel Removal 1. Disconnect power supply to unit. 2. Remove Top Cover. 3. Remove Console. 4. Open door and remove Boot Retainer Clamp. Expand the Boot Clamp Spring located at the 6 o’clock position 5. Pull the boot from the lip formed into the front opening. 6. Remove four screws attaching the front to the cabinet. 7. Disconnect the wire connectors to the Door Lock 8. Lift Front Panel from bottom brackets Boot Removal 1. Disconnect power supply to unit. 2. Remove Top Cover. 3. Remove Console. 4. Remove Front Panel. 5. Loosen boot clamp at the 12 o’clock position NOTE: When installing the boot align the index tabs on the boot with the screws on either side of the Fill Tube
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
[quote=Joe / APP Team;304027]Octavio,
Here are excerpts from the Service Manual for your unit, in reference to the boot access and removal procedure. It'll take some time, but you'll be able to handle it, and be up and running in no time. Good Luck, Top Removal 1. Disconnect power supply to unit. 2. Remove 2 10mm screws from washer back 3. Slide Top Cover towards the rear to clear the screw head from flange on the bottom side of the Top Cover Dispenser Removal 1. Disconnect power supply to unit. 2. Depress the release tab and slide drawer from washer Console Removal 1. Disconnect power supply to unit. 2. Remove Top Cover. 3. Remove Dispenser Drawer. 4. Remove five screws attaching Console 5. Roll Console down and lift away from washer. 6. Remove Reactor wire harness from wire clip.7. Remove Reactor wire harness connector from the PCB Board. 8. Remove five screws from PCB Housing to access the LED Circuit Board Front Panel Removal 1. Disconnect power supply to unit. 2. Remove Top Cover. 3. Remove Console. 4. Open door and remove Boot Retainer Clamp. Expand the Boot Clamp Spring located at the 6 o’clock position 5. Pull the boot from the lip formed into the front opening. 6. Remove four screws attaching the front to the cabinet. 7. Disconnect the wire connectors to the Door Lock 8. Lift Front Panel from bottom brackets Boot Removal 1. Disconnect power supply to unit. 2. Remove Top Cover. 3. Remove Console. 4. Remove Front Panel. 5. Loosen boot clamp at the 12 o’clock position NOTE: When installing the boot align the index tabs on the boot with the screws on either side of the Fill Tube Joe: Thanks a lot Buddy. I will get it done.
__________________
ignoranceisnotbliss |
Octavio,
You're quite welcome, Don't hesitate to drop us a line, if you have a problem. Good Luck,
__________________
| Display Modes | |
| repacing door boot seal | Nealrepair10 | Dishwasher Repair | 0 | 01-27-2010 10:22 AM |
| Replaced Door seal, door wont close | ggreen3 | Dishwasher Repair | 3 | 12-18-2008 09:17 AM |
| Tub to door boot (seal) | FDAR | Washer Repair | 2 | 12-03-2008 08:26 PM |
| door seal +boot +gasket install | misterfixall | Washer Repair | 0 | 10-30-2008 12:29 PM |
| Water leaking under door...need to know how to remove door & replace seal | edbolliera | Dishwasher Repair | 1 | 11-27-2007 03:42 AM |
