Discuss
Spin cycle not working
 in
Washer Repair
Washer works until it's time for spin cycle it stops working,and the water will not drain nor will the washer
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Spin cycle not working
  #1 (permalink)
Old 11-17-2010, 07:33 PM
Junior Member
nikki777 is on a distinguished road
Default Spin cycle not working
Model Number: 11O22442100   Brand: Kenmore   Age: 5 - 10 years
Washer works until it's time for spin cycle it stops working,and the water will not drain nor will the washer go into the spin cycle. I am then left with a tub full of water and a wet load of laundry. Any suggestions on what's causing this problem?I need help please.
Read more: Washer won't drain water nor spin
http://forum.appliancepartspros.com
Ads By Google
Related Models
Amana 12 Freezer - Vertical
Frigidaire 12-1063-00-04 Tap(v1) / Gas Range
Frigidaire 12-1063-00-05 Tap(v2) / Gas Range
Frigidaire 12-1063-23-04 Tap(v3) / Gas Range
Frigidaire 12-1063-23-05 Tap(v4) / Gas Range
Frigidaire 12-1063-45-04 Tap(v5) / Gas Range
Frigidaire 12-1063-45-05 Tap(v6) / Gas Range
Frigidaire 12-1063-57-04 Tap(v7) / Gas Range
Frigidaire 12-1063-57-05 Tap(v8) / Gas Range
Frigidaire 12-1063-66-04 Tap(v9) / Gas Range
Frigidaire 12-1063-66-05 Tap(v10) / Gas Range
Frigidaire 12-1263-00-01 Tap(v1) / Gas Range
Frigidaire 12-1263-23-01 Tap(v2) / Gas Range
Frigidaire 12-1263-45-01 Tap(v3) / Gas Range
Frigidaire 12-1263-57-01 Tap(v4) / Gas Range
Frigidaire 12-1263-66-01 Tap(v5) / Gas Range
Frigidaire 12-1663-00-01 Tap(v6) / Gas Range
Frigidaire 12-1663-23-01 Tap(v7) / Gas Range
Frigidaire 12-1663-45-01 Tap(v8) / Gas Range
Frigidaire 12-1663-57-01 Tap(v9) / Gas Range
Frigidaire 12-1663-66-01 Tap(v10) / Gas Range
Frigidaire 12-1863-00-01 Tap(v1)
Frigidaire 12-1863-00-02 Tap(v2)
Frigidaire 12-1863-00-03 Tap(v1) / Gas Wall Oven
Frigidaire 12-2299-00-01 Tap(v1) / Wall Oven
Frigidaire 12-2299-00-02 Tap(v1) / Wall Oven
Frigidaire 12-2299-00-03 Tap(v1) / Wall Oven
Frigidaire 12-2299-00-04 Tap(v2) / Wall Oven
Frigidaire 12-2299-00-06 Tap(v1) / Wall Oven
Frigidaire 12-2299-10-05 Tap(v1) / Wall Oven
Amana 12-2MW Room Air Conditioner
Amana 12-2N Room Air Conditioner
Amana 12-2NM Room Air Conditioner
Frigidaire 12-3219-00-01 Tap(v1) / Gas Wall Oven
Frigidaire 12-3699-00-01 Tap(v1) / Gas Wall Oven
Frigidaire 12-3699-00-04 Tap(v1) / Gas Wall Oven
Frigidaire 12-3699-00-05 Tap(v1) / Gas Wall Oven
Frigidaire 12-3883-00-01 Tap(v11) / Gas Range
Frigidaire 12-3883-23-01 Tap(v12) / Gas Range
Frigidaire 12-3883-45-01 Tap(v13) / Gas Range
Frigidaire 12-3883-57-01 Tap(v14) / Gas Range
Frigidaire 12-3883-66-01 Tap(v15) / Gas Range
Frigidaire 12-3893-00-01 Tap(v11) / Gas Range
Frigidaire 12-3893-23-01 Tap(v12) / Gas Range
Frigidaire 12-3893-45-01 Tap(v13) / Gas Range
Frigidaire 12-3893-57-01 Tap(v14) / Gas Range
Frigidaire 12-3893-66-01 Tap(v15) / Gas Range
Amana 12-3G Room Air Conditioner
Amana 12-3GH Room Air Conditioner
Amana 12-3GM Room Air Conditioner
Amana 12-3J Room Air Conditioner
Amana 12-3JH Room Air Conditioner
Amana 12-3JM Room Air Conditioner
Frigidaire 12-4980-00-01 Tap(v1) / Gas Wall Oven
Frigidaire 12-4980-00-03 Tap(v1) / Gas Wall Oven
Frigidaire 12-4980-00-04 Tap(v1) / Gas Wall Oven
Frigidaire 12-4980-00-05 Tap(v1) / Gas Wall Oven
Frigidaire 12-4990-00-01 Tap(v1) / Gas Wall Oven
Frigidaire 12-4990-00-02 Tap(v1) / Gas Wall Oven
Frigidaire 12-4990-00-03 Tap(v1) / Gas Wall Oven
Frigidaire 12-4990-00-04 Tap(v1) / Gas Wall Oven
Frigidaire 12-5063-00-04 Tap(v16) / Gas Range
Frigidaire 12-5063-00-05 Tap(v17) / Gas Range
Frigidaire 12-5063-23-04 Tap(v18) / Gas Range
Frigidaire 12-5063-23-05 Tap(v19) / Gas Range
Frigidaire 12-5063-45-04 Tap(v20) / Gas Range
Frigidaire 12-5063-45-05 Tap(v21) / Gas Range
Frigidaire 12-5063-57-04 Tap(v22) / Gas Range
Frigidaire 12-5063-57-05 Tap(v23) / Gas Range
Frigidaire 12-5063-66-04 Tap(v24) / Gas Range
Frigidaire 12-5063-66-05 Tap(v25) / Gas Range
Frigidaire 12-5299-00-01 Tap(v2) / Wall Oven
Frigidaire 12-5299-00-02 Tap(v1) / Wall Oven
Frigidaire 12-5299-00-04 Tap(v2) / Wall Oven
Frigidaire 12-6219-00-01 Tap(v2) / Gas Wall Oven
Frigidaire 12-6263-00-01 Tap(v16) / Gas Range
Frigidaire 12-6263-23-01 Tap(v17) / Gas Range
Frigidaire 12-6263-45-01 Tap(v18) / Gas Range
Frigidaire 12-6263-57-01 Tap(v19) / Gas Range
Frigidaire 12-6263-66-01 Tap(v20) / Gas Range
Frigidaire 12-6663-00-01 Tap(v21) / Gas Range
Frigidaire 12-6663-23-01 Tap(v22) / Gas Range
Frigidaire 12-6663-45-01 Tap(v23) / Gas Range
Frigidaire 12-6663-57-01 Tap(v24) / Gas Range
Frigidaire 12-6663-66-01 Tap(v25) / Gas Range
Frigidaire 12-6699-00-01 Tap(v2) / Gas Wall Oven
Amana 120
Amana 120.000 Mwave - Family Size (60 Hz)
Amana 120.001 Mwave - Family Size (60 Hz)
Maytag 12001294 Misc / Accessory
Maytag 12001302 Misc / Accessory
Maytag 12001685 Misc / Accessory
Maytag 12001686 Misc / Accessory
Maytag 12001687 Misc / Accessory
Maytag 12001688 Misc / Accessory
Maytag 12001747 Misc / Accessory
Thermador 1201
Thermador 1205
Amana 120A
Amana 120B
Jenn-Air 12103 Surface Unit - Ddraft Gas
Jenn-Air 12104 Surface Unit - Ddraft Gas
Jenn-Air 1210485 Surface Unit - Ddraft Gas
Jenn-Air 1210486 Surface Unit - Ddraft Gas
Whirlpool 1212W0A
Whirlpool 1212W2A
Whirlpool 1212Z1A
Whirlpool 1212Z2A
Whirlpool 1212^0A
Whirlpool 1212^1A
Whirlpool 1213W0A
  #2 (permalink)
Old 11-19-2010, 04:45 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Try by passing the lid switch as it is the likely problem.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Spin cycle not working 1madison1 Washer Repair 0 09-06-2010 10:09 AM
Breaker trip before spin cycle, spin not working kevbayer Washer Repair 5 02-27-2010 05:00 PM
Spin cycle not working jonb89 Washer Repair 1 02-14-2010 06:46 AM
spin cycle not working gary n Washer Repair 1 08-09-2008 02:01 PM
Spin cycle not working Rappl Washer Repair 0 02-19-2008 07:31 AM
