| » Tub Bamming W/ Spin , Belt Slipping, Then Cuts Off |
Model Number: LA482 Brand: -brand- Age: Less than 1 year
Interesting Problem When Got Home Last Nite - 20 Yr Old Top Load Mayatg Started Making Extremely Loud Bam, Bam, Bam Noise When Starting To Spin, Belt Was Smoking And Then It Cut Off. Wife Was Pissed , So We Went Out Looking At New Washers. Found Out Maytag Is Now Owned By Whirlpool And Seems To Have Adopted The Whirlpool Designs (which Probably Are Ok , But I Have Always Been Impressed With The Maytag Simplicity And Durability) So.....
Initial (car Guy Type) Troubleshooting Indicates Nothing Obviously Amiss From Underneath other than belt has minor stretching. All Shafting Turns Freely By Hand in either direction. For Grins Went Ahead And Bypassed The Lid Switch... no joy --> Still Bams, Smokes, Then Cuts Off (MACHINE IS EMPTY-NO LOAD) As A Wash Machine Repair Novice, It Behaves Like The Counterbalance Weight Mechanism Has Run Amuck OR a brake mechanism is being energized If There Are Some Simple Checks I Can Perform, Or Suggestions You May Have, Pls Advise Sc Last edited by STEVE COX : 10-04-2007 at 01:09 PM. Reason: more details |
Sounds like your spin basket has broken loose!! Just try to lift up on the spin basket, and check. Pull agitator, (it has a 1/4 inch screw holding it in ) and check.
__________________
| Display Modes | |
| Top agitator slipping | robejahori | Washer Repair | 7 | 04-23-2008 10:14 AM |
| Whirlpool belt-drive won't spin when it's supposed to | Lmarks | Washer Repair | 13 | 10-03-2007 05:41 PM |
| frigidaire dishwasher cuts out after 5 min | fredsaid | Dishwasher Repair | 2 | 08-21-2007 08:46 PM |
| Drive block keeps slipping. | vanmaarth | Washer Repair | 3 | 08-15-2007 09:00 PM |
| Washer won't drain during spin cycle. Water Pump Belt discovered on floor | sandydjdm | Washer Repair | 1 | 08-14-2007 08:41 PM |
