Discuss
Maytag washer squeels on spin
 in
Washer Repair
My Maytag washer squeels on spin. This happens off and on. What should I look at as the most likely
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag washer squeels on spin
  #1 (permalink)
Old 11-17-2010, 01:34 AM
Junior Member
bridgewater is on a distinguished road
Default Maytag washer squeels on spin
Model Number: SAV365ZAWW   Brand: Maytag   Age: 5 - 10 years
My Maytag washer squeels on spin. This happens off and on. What should I look at as the most likely culprets and how hard is it to work on this unit?
Ads By Google
Related Models
Maytag SAV365ZAWW Washer - Top Loading
Maytag SAV3710AWW Washer - Top Loading
Maytag SAV405DAWW Washer - Top Loading
Maytag SAV405DEWW Washer - Top Loading
Maytag SAV4655AWQ Washer - Top Loading
Maytag SAV4655AWW Washer - Top Loading
Maytag SAV4655EWQ Washer - Top Loading
Maytag SAV4655EWW Washer - Top Loading
Maytag SAV4710AWW Washer - Top Loading
Maytag SAV505DAWQ Washer - Top Loading
Maytag SAV505DAWW Washer - Top Loading
Maytag SAV515DAWW Washer - Top Loading
Maytag SAV515DEWW Washer - Top Loading
Maytag SAV5300AWW Washer - Top Loading
Maytag SAV5401AWQ Washer - Top Loading
Maytag SAV5401AWW Washer - Top Loading
Maytag SAV5600AWW Washer - Top Loading
Maytag SAV5701AWQ Washer - Top Loading
Maytag SAV5701AWW Washer - Top Loading
Maytag SAV5710AWW Washer - Top Loading
Maytag SAV571EEWW Washer - Top Loading
Maytag SAV5910AWW Washer - Top Loading
Maytag SAV5910EWW Washer - Top Loading
Maytag SAW25K3S Washer - Top Loading
Whirlpool SAWB600HQ0
Whirlpool SAWB600JQ0
Whirlpool SAWB600JQ1
Whirlpool SAWS800HQ0
Whirlpool SAWS800JQ0
Whirlpool SAWS800JQ1
Whirlpool SAWS800JQ2
Whirlpool SAWS800MQ0 Automatic Washer
Whirlpool SAWS900HQ0
Whirlpool SAWS900JQ0
Whirlpool SAWS900MQ0 Automatic Washer
Whirlpool SAWX650JQ0
Whirlpool SAWX650MQ0 Automatic Washer
Whirlpool SAWX650MQ2 Automatic Washer
Whirlpool SB1000SKN0
Whirlpool SB100PEDB0
Whirlpool SB100PEDB1
Whirlpool SB100PEDB2
Whirlpool SB100PEDB4
Whirlpool SB100PEDB5
Whirlpool SB100PEK0
Whirlpool SB100PEK1
Whirlpool SB100PER0
Whirlpool SB100PES0
Whirlpool SB100PES1
Whirlpool SB100PES2
Whirlpool SB100PES3
Whirlpool SB100PES4
Whirlpool SB100PSK0
Whirlpool SB100PSK1
Whirlpool SB100PSR0
Whirlpool SB100PSR1
Whirlpool SB130PEDB0
Whirlpool SB130PEDB1
Whirlpool SB130PEDB2
Whirlpool SB130PEK0
Whirlpool SB130PER1
Whirlpool SB130PER2
Whirlpool SB130PER3
Whirlpool SB130PER4
Whirlpool SB130PER5
Whirlpool SB130PERW0
Whirlpool SB130PSK0
Whirlpool SB160PEDB0
Whirlpool SB160PEDB1
Whirlpool SB160PEDB2
Whirlpool SB160PEDB4
Whirlpool SB160PEDQ0
Whirlpool SB160PEDQ1
Whirlpool SB160PEDQ2
Whirlpool SB160PEDQ4
Whirlpool SB160PEEB1
Whirlpool SB160PEEB2
Whirlpool SB160PEEB5 24" Built - in - Oven Gas
Whirlpool SB160PEEB6
Whirlpool SB160PEEB7
Whirlpool SB160PEEB8
Whirlpool SB160PEEB9
Whirlpool SB160PEEQ1
Whirlpool SB160PEEQ2
Whirlpool SB160PEEQ5 24" Built - in - Oven Gas
Whirlpool SB160PEEQ6
Whirlpool SB160PEEQ7
Whirlpool SB160PEEQ8
Whirlpool SB160PEEQ9
Whirlpool SB160PEXB0
Whirlpool SB160PEXB1
Whirlpool SB160PEXQ0
Whirlpool SB160PEXQ1
Amana SB21VE Ref - SXS/I&W
Amana SB21VPSE Ref - SXS/I&W
Amana SB21VW Ref - SXS/I&W
Thermador SB2B
Amana SB520K Ref - SXS/I&W
Amana SB520SW Ref - SXS/I&W
Amana SB520TW Ref - SXS/I&W
Amana SBC24FX0 Range - Electric Std Delaware
Amana SBC24FX5 Range - Electric Std Delaware
Amana SBC24FXOW Range - Electric Std Delaware
Amana SBC26CK Range - Electric Std Delaware
Amana SBD20H Ref - SXS/I&W
Amana SBD20J Ref - SXS/I&W
Amana SBD20K Ref - SXS/I&W
Amana SBD20M Ref - SXS/I&W
Amana SBD20MW Ref - SXS/I&W
Amana SBD20NE Ref - SXS/I&W
Amana SBD20NW Ref - SXS/I&W
Amana SBD20Q2E Ref - SXS/I&W
Amana SBD20Q2W Ref - SXS/I&W
Amana SBD20S4E Ref - SXS/I&W
  #2 (permalink)
Old 11-17-2010, 06:55 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Bridgewater,
Any other noises when it's washing or spinning ?
When does the noise occur, start, middle, end of the spin cycle ?
Hopefully, it's as simple as a worn belt and or Idler pulley.
Part number: AP4035118
Part number: AP4048267
And not a bad tub bearing, spin bearing or brake rotor.
Part number: AP4261193
Part number: AP4047999
Part number: AP4253879
These are rather involved repairs, but doable.
You should be able to remove the lower front access panel, and isolate the noise location, we'd have a better idea what to expect, investigate.
Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 11-17-2010, 03:15 PM
Junior Member
Red face
Thank you very much for your help. I removed the bottom front panel of the washer while running & noticed that the Idler pulley would spin off & on making 2 noises. It would take a while but when the Idler pully stopped I would hear a high pitched squeal. I also noticed that the back of the Belt was worn smooth from friction on the stationary Idler pulley. When the Idler pulley wheel would randomly spin again it would make an intermittent chirp. I assume that I should replace both the Idler pulley wheel and the belt.
While looking I also noticed that the Idler pulley wheel was not directly in line with the Spin pulley & Motor pulley. The Belt rides low on the Idler pulley.
1- Do I remove the whole motor/Pump assembly to replace the 2 parts?
2- Should I try to align the new Idler pulley?
Much thanks again for your Help.
  #4 (permalink)
Old 11-18-2010, 06:35 AM
Senior Expert
Default
Bridgewater,
That's what I was thinking / hoping .
Here's excerpts from the service manual, that should help you.
Besides the parts I mentioned in the previous post(belt, idler pulley) also order the idler assembly spring, I think you'll be happier in the long run.
Part number: AP4047318
Motor Disassembly
1. Remove nuts, steel washers, spacers and rubber
mounts securing motor to mounting bracket
2. Lift motor off mounting bracket and remove
remaining rubber mounts and steel washers from
motor mounting studs.
NOTE:
When installing motor on mounting bracket,
position motor with switch facing toward left side
of mounting bracket
NOTE:
When assembling motor to motor bracket, it is
extremely important to make sure the motor is
centered on isolator pads and all fasteners are
evenly torqued.
Pump and Belt Removal
1. Remove motor, see “Motor and Mounting Bracket”
procedure.
2. Remove screws securing pump assembly to motor.
Reassembly of Pump and Belt
NOTE:
Install pump and belt together. Drive belt MUST
be replaced with belt No. 40053602 for one and
two speed models; or 40053601 for some two
speed models and three speed models (special
clutch-type belt) for proper washer operation.
Refer to Parts Manual for proper belt part
number.
1. Remove any corrosion or foreign material from motor
shaft.
2. Apply a thin film of No. 03637P lubricant to the end
and sides of motor shaft.
NOTE:
This lubricant helps keep moisture out of the
hub area and prevents corrosion.
3. Align belt on motor pulley and tension pulley as
illustrated.
4. Align pump impeller hub with motor shaft. Verify belt
encircles rear pump leg. Slide pump onto motor
shaft until legs touch the embosses on the motor
housing before securing.
NOTE:
Tighten screws to 35 inch-pounds maximum.
DO NOT overtighten screws!
5. Install motor and pump assembly into washer, see
“Motor and Mounting Bracket” procedure.
NOTE:
After installing motor and pump assembly in the
washer and all hoses have been secured, along
with reconnecting idler spring. Add at least one
quart of water to washtub to lubricate pump
seals. Running a pump without water will
damage the seals
Idler Lever and Pulley
procedure.
NOTE:
Lay motor on its side. Observe belt
configuration around rear pump leg. Belt
MUST
encircle rear pump leg when reassembling.
2. Remove nut, washer, and bolt securing idler lever
and pulley to motor mounting bracket.
3. Apply a light film of No. 03637P Lubricant to area of
idler lever that makes contact with motor mounting
bracket.
NOTE: DO NOT OVER LUBRICATE!
Excess lubricant
can be thrown into pivot dome area during
normal washer operation. Any lubricant on the
pivot dome, base or friction ring will affect
washer operation.
4. Reverse procedure to reassemble.
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag squeels when spinning rustbelt Washer Repair 2 02-27-2010 12:23 PM
Maytag washer won't spin on spin cycle steve2zastrow Washer Repair 0 11-27-2009 09:04 AM
Maytag washer will not spin Teddyk Washer Repair 4 10-15-2009 07:26 PM
squeels at start of spin cycle rdean Washer Repair 1 10-03-2009 12:50 PM
Maytag washer won't spin mmorse44 Washer Repair 5 08-07-2008 03:56 AM
