Discuss
Kitchenaid: fills, agitates, won't spin or drain
 in
Washer Repair
Approx. 1994 washer: fills & agitates, but won't spin or drain. Does make a slight buzzing sound. When I first
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kitchenaid: fills, agitates, won't spin or drain
  #1 (permalink)
Old 11-08-2008, 12:07 PM
Junior Member
spaldini101 is on a distinguished road
Question Kitchenaid: fills, agitates, won't spin or drain
Model Number: kawe660wwh3   Brand: Kitchen Aid   Age: More than 10 years
Approx. 1994 washer: fills & agitates, but won't spin or drain. Does make a slight buzzing sound. When I first discovered it there was a "over-heated motor" smell. After letting the motor cool I tried it again and heard the buzzing sound.
Have disconnected the hoses to and from the pump... no clog. Checked the drain hose all the way to the wall drain, no clog. Removed the pump and it turns easily. The motor shaft that drives the pump also turns easily. Checked the lid switch for continuity and it also is functioning properly. The tub turns by hand, but w/ slight resistance... dragging brakes? Is this the problem?
Related Models
Whirlpool KAWE660WWH3
Whirlpool KAWE665BWH0 AUTOMATIC WASHER
Whirlpool KAWE667BWH0
Whirlpool KAWE667BWH1 AUTOMATIC WASHER
Whirlpool KAWE668BAL0
Whirlpool KAWE668BAL1
Whirlpool KAWE670BAL0
Whirlpool KAWE670BWH0
Whirlpool KAWE670BWH1
Whirlpool KAWE677BWH0
Whirlpool KAWE677BWH1
Whirlpool KAWE678BAL0
Whirlpool KAWE678BAL1
Whirlpool KAWE679BBL0
Whirlpool KAWE679BBL1
Whirlpool KAWE700TWH0
Whirlpool KAWE742BAL0
Whirlpool KAWE742BWH0
Whirlpool KAWE742VAL0
Whirlpool KAWE742VWH0
Whirlpool KAWE742WAL0
Whirlpool KAWE742WAL1
Whirlpool KAWE742WAL2
Whirlpool KAWE742WAL3
Whirlpool KAWE742WWH0
Whirlpool KAWE742WWH1
Whirlpool KAWE742WWH2
Whirlpool KAWE742WWH3
Whirlpool KAWE750VAL0
Whirlpool KAWE750VWH0
Whirlpool KAWE755VAL0
Whirlpool KAWE755VWH0
Whirlpool KAWE760WAL0
Whirlpool KAWE760WAL1
Whirlpool KAWE760WAL2 AUTOMATIC WASHER
Whirlpool KAWE760WAL3 AUTOMATIC WASHER
Whirlpool KAWE760WWH0
Whirlpool KAWE760WWH1
Whirlpool KAWE760WWH2
Whirlpool KAWE760WWH3
Whirlpool KAWE764WAL0
Whirlpool KAWE764WAL1
Whirlpool KAWE764WAL2
Whirlpool KAWE764WWH0
Whirlpool KAWE764WWH1
Whirlpool KAWE764WWH2
Whirlpool KAWE767BWH0
Whirlpool KAWE767WAL0
Whirlpool KAWE767WWH0
Whirlpool KAWE768BAL0
Whirlpool KAWE768BAL1
Whirlpool KAWE768BWH0
Whirlpool KAWE770BAL0
Whirlpool KAWE770BWH0
Whirlpool KAWE770BWH1
Whirlpool KAWE777BWH0
Whirlpool KAWE777BWH1
Whirlpool KAWE778BAL0
Whirlpool KAWE778BAL1
Whirlpool KAWE800SWH1
Whirlpool KAWE800TWH0
Whirlpool KAWE842WAL0
Whirlpool KAWE842WAL1
Whirlpool KAWE842WAL2
Whirlpool KAWE842WWH0
Whirlpool KAWE842WWH1
Whirlpool KAWE842WWH2
Whirlpool KAWE850VAL0
Whirlpool KAWE850VAL1
Whirlpool KAWE850VWH0
Whirlpool KAWE850VWH1
Whirlpool KAWE860WAL0
Whirlpool KAWE860WAL1
Whirlpool KAWE860WAL2
Whirlpool KAWE860WAL3
Whirlpool KAWE860WWH0
Whirlpool KAWE860WWH1
Whirlpool KAWE860WWH2
Whirlpool KAWE860WWH3
Whirlpool KAWE870BAL0
Whirlpool KAWE870BWH0
Whirlpool KAWE870BWH1
Whirlpool KAWE877BWH1
Whirlpool KAWE878BAL1
Whirlpool KAWE900SWH1
Whirlpool KAWE900SWH2
Whirlpool KAWE900TWH0
Whirlpool KAWE900TWH1
Whirlpool KAWE950VAL0
Whirlpool KAWE950VWH0
Whirlpool KAWE960WAL0
Whirlpool KAWE960WAL1
Whirlpool KAWE960WWH0
Whirlpool KAWE960WWH1
Whirlpool KAWE977BWH0
Whirlpool KAWE977DWH0
Whirlpool KAWL400WAL0
Whirlpool KAWL400WAL1
Whirlpool KAWL400WWH0
Whirlpool KAWL400WWH1
Whirlpool KAWL410BAL0
Whirlpool KAWL410BWH0
Whirlpool KAWL410BWH1
Whirlpool KAWL500WAL0
Whirlpool KAWL500WWH0
Whirlpool KAWL510BAL0
Whirlpool KAWL510BWH0
Whirlpool KAWL517BWH0
Whirlpool KAWL517BWH1
Whirlpool KAWS577EQ0 DIRECT-DRIVE WASHER
Whirlpool KAWS577EZ0 DIRECT-DRIVE WASHER
Whirlpool KAWS677EQ0 DIRECT-DRIVE WASHER
Whirlpool KAWS677EZ0 DIRECT-DRIVE WASHER
Whirlpool KAWS700EQ0 DIRECT-DRIVE HOME WASHERS
Whirlpool KAWS700EZ0 DIRECT-DRIVE HOME WASHERS
Whirlpool KAWS700GQ0 AUTOMATIC WASHER
Whirlpool KAWS700GT0 AUTOMATIC WASHER
Whirlpool KAWS700GZ0 AUTOMATIC WASHER
Whirlpool KAWS700JQ0 RESIDENTIAL WASHER
Whirlpool KAWS700JQ1 RESIDENTIAL WASHERS
  #2 (permalink)
Old 11-09-2008, 07:16 AM
Senior Expert
APP Volunteer
v2k04 is on a distinguished road
Default
Are you possitive it agitates? Remove the motor and check the coupler
__________________
  #3 (permalink)
Old 11-09-2008, 07:34 AM
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
If it does agitate, check the pump and hoses for an obstruction.
Nat
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com
We are also Ministers that do a weekly jail house ministry.
Rate Liberty Appliance Service on MyPros.com
  #4 (permalink)
Old 11-09-2008, 08:22 AM
Junior Member
Default
If memory serves me... (and it doesn't always).. I believe it agitates fine. Where exactly is the coupler (between the motor and the transmission?), what does it look like, and what am I checking it for?
  #5 (permalink)
Old 11-09-2008, 10:04 AM
Junior Member
Default
Found the coupler... a 3-piece affair, right? One 3-pronged plastic piece to the motor, 1 to the trans, and the other connecting those 2 to each other. Nothing broken or frozen, motor turns easily, transmission turns easily and makes the agitator turn. Maybe, if there was an obstruction, it spilled out w/ the remaining water when I disconnected the pump, but I think I would have seen something.
Is there any reason to pull the agitator and look under there? It moves easily, too. Also, don't see anything between the plastic outer tub and the perforated inner steel tub. But, like I said in the original post... there is a humming or buzzing type of sound that occurs when the spin cycle should be starting. The type of sound you hear when an electric motor wants to start, but can't.
Maybe I should I put the whole thing back together again and see what happens. It's just that siphoning the water out was a pain, and the ensuing flood when pulling the pump.
  #6 (permalink)
Old 11-10-2008, 06:15 AM
Senior Expert
APP Volunteer
Default
With what you've checked so far I would try to start it and see what happens. Your brake or clutch may be locking up though.
Nat
__________________
  #7 (permalink)
Old 11-10-2008, 06:36 AM
Senior Expert
APP Volunteer
Default
If you haven't put it back to gether and providing you tore it down properly with backplate, control panel attached, tub assy and baseplate standing with just the wrapper off. Remove motor and set aside leaving wires hooked up. fill machine and see if motor runs,jumper lid switch and see if it runs in spin. if not jiggle wires on motor and check capacitor, jiggle knob on timer and see if it will make it run and not hum if it doesn't run you have a bad timer or a bad motor or a problem with the wiring.if it does run that will tell you the electrical is probably ok and your problem is mechanical, that will narrow it down anyway
__________________
  #8 (permalink)
Old 12-03-2008, 06:54 PM
Junior Member
KennyB is on a distinguished road
Default Same problem
spaldini101, I have the same problem with a KAWE678BAL1 model Kitchenaid. Mine is also over 10 years old. When you hear the buzzing noise, mine did that too, I found a burned contact in the timer. To save time I replaced the timer but the problem continues. It runs through the wash cycle but stops dead on the rinse and that is all she wrote.
I suspect the motor capacitor is shot but I am just guessing. There must have been a good load on the electrical system that caused the contact to burn. I'm not sure what to do next, either the cap or replace the motor. I am going to do as sugested and remove the motor and try to run it. Have you had any luck?
  #9 (permalink)
Old 12-04-2008, 08:31 PM
Junior Member
Default
Problem solved. After looking over the electrical diagram I ruled out the motor or capacitor. The machine filled and went through the wash cycle but stopped on the rinse and would go no further. I ruled out the motor as it worked in the wash cycle. The timer is new, old one had a burned contact. I noticed that when it got to the rinse cycle the timer stopped and lost power. Only 3 things would cause that; 1, no power to the machine. That was out because it washed. 2, if the knob were pushed as if to change the cycle. I didn't do that. 3, it won't go into rinse if the lid is open. That was the problem! The lid switch was bad, I jumped the switch out of the curcuit and the machine is now working normally. You just have to remember if you open the lid during rinse/spin the machine will not stop. I may order a new switch or just leave it as is.
  #10 (permalink)
Old 12-05-2008, 06:23 AM
Junior Member
Default
Thanks for the reply KennyB, but one of the first things I did was to check the lid switch, and it was fine. The timer has not been ruled out yet, though. Next time I have a chance I'll look there.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Profile washer fills, drains, agitates, but won't spin PatrickCA Washer Repair 7 10-29-2009 04:04 PM
washer agitates won't drain or spin b2thej1 Washer Repair 1 08-05-2009 07:46 PM
washer fills and agitates but won't spin or drain Jim Bags Washer Repair 1 07-08-2009 07:57 AM
washer fills, and agitates,until first stop will not drain or spin cindee Washer Repair 0 01-08-2009 08:38 PM
