Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   amana washer leak (http://forum.appliancepartspros.com/washer-repair/141867-amana-washer-leak.html)
dledmons 11-13-2010 03:51 PM
amana washer leak
Leaks after cycle complete from bottom. All visible connections tight and dry. Can i fix this?
kayakcrzy 11-14-2010 06:13 AM
Quote:
It is the tub seal, that is leaking, and if you put the washer in a spin cycle is it loud. If so, you would need a spin bearing, and it would be best to replace the washer. Tom ********************************************
