Hi all! Thanks for making forums like these to help DIY guys like myself get things fixed
So I have a Maytag A512 washing machine and for years it worked great. The drum started to get off center and so would constantly stop during the rinse cycle. I took off the front and held it centered and it would work fine. So I replaced the belts which were really worn, the damper pads and the two little springs under the motor. So now I have new problems and can't seem to find a cure. It will run fine until the spin cycle and it will start to spin up, and then I will hear clicking noises from the motor and then it shuts off. It won't restart for a while, but does the same thing. I often smell a slight burnt electonric smell. Then the few times we got it through the spin cycle, then it went right on to the next cycle without stopping. What should I check? The belts are not too tight underneath. I don't know what else could be wrong?
Related ModelsMaytag
A512 Washer - Top Loading
Maytag
A512S Washer - Top Loading
Maytag
A512ST Washer - Top Loading
Maytag
A512T Washer - Top Loading
Jenn-Air
A516 Misc / Accessory
Jenn-Air
A516B Misc / Accessory
Jenn-Air
A518S Misc / Accessory
Jenn-Air
A519 Misc / Accessory
Jenn-Air
A519B Misc / Accessory
Jenn-Air
A519W Misc / Accessory
Jenn-Air
A521B Misc / Accessory
Jenn-Air
A521W Misc / Accessory
Jenn-Air
A526 Misc / Accessory
Jenn-Air
A526W Misc / Accessory
Jenn-Air
A527B Misc / Accessory
Jenn-Air
A527W Misc / Accessory
Jenn-Air
A530 Misc / Accessory
Jenn-Air
A530W Misc / Accessory
Admiral
A54F-5TKXW-R Walloven - S/c Gas
Admiral
A54F-5TKXWM-R Walloven - S/c Mwave Gas
Admiral
A54FK-5TKXWM-R Walloven - S/c Mwave Gas
Admiral
A54FN-5TKVW-R Walloven - S/c Gas
Admiral
A54FN-5TKVWM-R Walloven - S/c Mwave Gas
Admiral
A5651XRS Range - D/i Cont Clean Ele
Admiral
A5892XRS Range - S/c D/i Ele
Admiral
A5898VRV Range - S/c D/i Ele
Admiral
A5898XRB Range - S/c D/i Ele
Admiral
A59-5EXW-R Walloven - S/c Ele
Maytag
A590 Washer - Top Loading
Maytag
A590T Washer - Top Loading
Maytag
A5910 Washer - Top Loading
Admiral
A59E-5EXW-R Walloven - S/c Ele
Admiral
A59F-5TXW-R Walloven - S/c Ele
Admiral
A59F-5TXWM-R Walloven - S/c Mwave Ele
Admiral
A59FN-5TVW-R Walloven - S/c Ele
Admiral
A59FN-5TVWM-R Walloven - S/c Mwave Ele
Admiral
A59G-5TXW-R Range - F/s Std Ele
Admiral
A59GN-5TVW-R Range - F/s Std Ele
Frigidaire
A5LECC2 Frg(v3) / Room Air Conditioner
Frigidaire
A5LECDC2 Frg(v4) / Room Air Conditioner
Frigidaire
A5LECDD2 Frg(v13) / Room Air Conditioner
Frigidaire
A5LECDSD2 Frg(v14) / Room Air Conditioner
Frigidaire
A5LECUC2 Frg(v12) / Room Air Conditioner
Maytag
A606 Washer - Top Loading
Maytag
A606S Washer - Top Loading
Maytag
A608 Washer - Top Loading
Maytag
A608S Washer - Top Loading
Maytag
A610 Washer - Top Loading
Maytag
A612 Washer - Top Loading
Maytag
A612S Washer - Top Loading
Maytag
A612ST Washer - Top Loading
Maytag
A612T Washer - Top Loading
Maytag
A613 Washer - Top Loading
Maytag
A613T Washer - Top Loading
Admiral
A6257XRS Range - S/i Cont Clean Gas
Jenn-Air
A626 Misc / Accessory
Jenn-Air
A626B Misc / Accessory
Jenn-Air
A626W Misc / Accessory
Jenn-Air
A627B Misc / Accessory
Jenn-Air
A627W Misc / Accessory
Admiral
A6498VRV Range - S/c S/i Gas
Admiral
A6498XRS Range - S/c S/i Gas
Admiral
A64HN-4TKVW-R Range - S/c S/i Gas
Admiral
A6892XRS Range - S/c S/i Ele
Admiral
A6898VRV Range - S/c S/i Ele
Admiral
A6898XRB Range - S/c S/i Ele
Admiral
A68HK-6TXW-R Range - S/c S/i Ele
Maytag
A6910 Washer - Top Loading
Frigidaire
A6LECC2 Frg(v5) / Room Air Conditioner
Frigidaire
A6LECC3 Frg(v1) / Room Air Conditioner
Frigidaire
A6LECD2 Frg(v15) / Room Air Conditioner
Frigidaire
A6LECDC2 Frg(v13) / Room Air Conditioner
Frigidaire
A6LECDC3 Frg(v14) / Room Air Conditioner
Frigidaire
A6LECDD2 Frg(v16) / Room Air Conditioner
Frigidaire
A6LECUD2 Frg(v17) / Room Air Conditioner
Frigidaire
A6LECUSD2 Frg(v18) / Room Air Conditioner
Maytag
A700 Washer - Top Loading
Maytag
A700S Washer - Top Loading
Maytag
A702 Washer - Top Loading
Maytag
A702S Washer - Top Loading
Maytag
A710 Washer - Top Loading
Maytag
A710S Washer - Top Loading
Maytag
A712 Washer - Top Loading
Maytag
A712T Washer - Top Loading
Maytag
A7300 Washer - Top Loading
Maytag
A7400 Washer - Top Loading
Maytag
A7500 Washer - Top Loading
Maytag
A7500S Washer - Top Loading
Maytag
A7500W Washer - Top Loading
Maytag
A7800 Washer - Top Loading
Admiral
A79E-5CXW Walloven - S/c Ele
Admiral
A79F-5EXW-R Walloven - S/c Ele
Admiral
A79FN-5EVW-R Walloven - S/c Ele
Frigidaire
A7LECUD2 Frg(v19) / Room Air Conditioner
Maytag
A806 Washer - Top Loading
Maytag
A806S Washer - Top Loading
Maytag
A810 Washer - Top Loading
Maytag
A8100 Washer - Top Loading
Maytag
A8120 Washer - Top Loading
Maytag
A8140 Washer - Top Loading
Maytag
A8200 Washer - Top Loading
Maytag
A8210 Washer - Top Loading
Admiral
A8210PA Surface Unit - Gas
Admiral
A8210PA-L Surface Unit - Gas
Admiral
A8210PT-L Surface Unit - Gas
Admiral
A8210PW Surface Unit - Gas
Admiral
A8210PW-L Surface Unit - Gas
Admiral
A8211PA Surface Unit - Gas
Admiral
A8211PS Surface Unit - Gas
Admiral
A8211PW Surface Unit - Gas
Maytag
A8240 Washer - Top Loading
Admiral
A8241RA Surface Unit - Gas
Admiral
A8241RA-L Surface Unit - Gas
Admiral
A8241RS Surface Unit - Gas
Admiral
A8241RT-L Surface Unit - Gas
Admiral
A8241RV Surface Unit - Gas
Admiral
A8241RW Surface Unit - Gas
Admiral
A8241RW-L Surface Unit - Gas
Admiral
A8261RB Surface Unit - Gas
Admiral
A8261RV Surface Unit - Gas
