Discuss
Frigidair Front Loading Washer Fill and Cycle Problems
 in
Washer Repair
It is about 3 years old. Frigidair front loading washer. It was working fine then all of a sudden it
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Frigidair Front Loading Washer Fill and Cycle Problems
  #1 (permalink)
Old 11-12-2010, 04:09 PM
Junior Member
Capron09 is on a distinguished road
Default Frigidair Front Loading Washer Fill and Cycle Problems
Brand: Frigidaire   Age: 1 - 5 years
It is about 3 years old. Frigidair front loading washer. It was working fine then all of a sudden it gave me a probem. It would not fill on any of the cycles other than the regular cycle but only if you set it to just before regular it starts with a small fill up, about 40 seconds with loud humming or grinding noise and then goes into spin and drain cycles. Then it seems like it starts washing only there is not enough water becasuse it seems to be washing with the rinse water. YET I hear it draining. It is leaving my softner in the tray. It is running very smooth and sounds fine except fo the initial small fill it does. I think its the water pump. It did this on the hot/cold cycle and the cold cycle but m not sure about the HOT cycle as I have not done one of those yet. Any help would be appreciated greatly! We just dropped replaced a fuel pump on our truck so fixing a wash machine really will be difficult. My hubby is very handy with tinkering around but he doesnt tinker with appliances! So if you just explain what parts your speaking of then, well get it! Thank you again!
Ads By Google
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire Front Loading Spin Cycle - ATF7000EE0 carbw Washer Repair 1 09-16-2010 05:13 PM
loud noise on spin cycle front loading washer JLR Washer Repair 1 03-05-2010 11:39 AM
Whirlpool front loading washer spinning problems godp1301 Washer Repair 2 02-23-2010 06:24 AM
front loading washer off balance in spin cycle bruciemom Washer Repair 4 12-10-2008 10:14 AM
banging noise on spin cycle front loading blaise Washer Repair 0 10-04-2008 02:22 PM
