Discuss
whirlpool duet F05 code
 in
Washer Repair
To check the wiring harness, set your multimeter to check continuity, and then simply connect the probes - one to
Appliance Repair Forum > Appliance Repair Help > Washer Repair » whirlpool duet F05 code
  #21 (permalink)
Old 08-20-2014, 04:33 AM
Junior Member
twarnock is on a distinguished road
Default Wiring harness check
To check the wiring harness, set your multimeter to check continuity, and then simply connect the probes - one to each end of the wire (one at then sensor and the other at the CCM.) I don't remember if they're color coded, but it's a short enough run from top to bottom that you should be able to figure out each pair and where it goes. You want to make sure there's not a break inside the Wire. If you do, simple run a replacement wire for whichever one is broken....no need to order and replace the entire harness. Let me know if that doesn't make sense.
  #22 (permalink)
Old 08-20-2014, 06:41 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Originally Posted by bubver View Post
Having same problem, f05 code after 2-3 minutes and only hot water regardless of setting. Can you tell me how to perform resistance checks on wire harness at ccu, heater element and heat relay? I have tested water temp sensor and it tests fine... but I am a novice and do not know how to check the other things. Thanks
Bubver, We know the thermistor checks OK, so the next move is to remove the TH2 connector from the CCU, and check for 9 to 10 ohms resistance across the two wires in the connector. If you have the resistance, then the thermistor and wire harness are intact and operable, the issue would be in the CCU. If your washer is equipped with a heater element, there should be a resistance(closed circ.) reading across the two heater terminals, if there is no resistance (open circ.) then the heater has failed and needs to be replaced. You can disconnect the HE2 connector from the CCU, and check across pin 1 and pin 2 in the harness and check for a "closed" circuit, this will check the heater and the wire harness.
If the resistances at the CCU are incorrect, then you'll need to start checking the wiring harness using Twarnock's methods.
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpool Duet error code H/F androck Washer Repair 3 08-18-2013 06:14 AM
Whirlpool Duet Error Code F-11 swampkritter Washer Repair 5 04-14-2011 02:22 PM
whirlpool duet error code FH misterfixall Washer Repair 13 11-10-2010 10:32 AM
Whirlpool Duet-no error code but won't run grapeape1223 Washer Repair 1 08-24-2010 07:29 PM
Whirlpool duet f11 code jbpompier Washer Repair 0 04-02-2010 07:59 AM
