The machine seems to fill normally on all load settings for a wash but will ocassionally not stop filling on the rinse cycle. The water level switch seems to be functioning properly and the air tube is not blocked or pinched. I'm told the timer is rarely the issue and dont want to buy a new one before I know its causing the problem. Any suggestions?
