The agitator will only spin in circles unless i put pressure on it then it will agitate. how do i remove the plastic housing to check the gears underneath it?
The agitator willl pull off (this is difficult, and be careful, it may release suddently). This part may solve your problem, it is under the agitator. Part number: AP3964635
