| » HE3 dryer stacked on HE3t--remove pump? |
Model Number: 110.42922200 Brand: Kenmore Age: 5 - 10 years
Is there any problem with removing the water pump from my washer (HE3t) while the gas Dryer (HE3) is stacked on top of it? Any reason why I should not stack them?
Initially 02 code, cleaned filter but suspect other problem as there is sporadic clunking and stopping of the drum when it is turned by hand. Ads By Google Related Models |
The water pump should be accessible from the front and I don't see why you can not stack the dryer on top of the washer if they are specifically designed to be stacked.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
You are welcome.
If the dryer is properly installed and mounted on top of the washer then there is no worry about stability. Gene.
__________________
THANK YOU again for your help. You are saving this DIYer lots of money, which is really appreciated (I've been out of work 2 years as of yesterday).
I believe I either have something between the tub and basket Thanks again!!! |
| Display Modes | |
| HE3t-02 code found unk items in pump filter | BikerWoman | Washer Repair | 1 | 11-09-2010 03:42 PM |
| dryer, stacked | warzdad | Dryer Repair | 4 | 08-25-2010 12:28 PM |
| HE3T Drain Pump | Jim Bo | Washer Repair | 2 | 10-28-2009 06:41 PM |
| Pump Motor on Kenmore HE3t | Bill Neff | Washer Repair | 4 | 05-24-2009 05:30 PM |
| stacked washer dryer | housewife | Washer Repair | 0 | 06-05-2008 08:11 AM |
