Discuss
Neptune TL Washer does not spin dc code on LED screen
 in
Washer Repair
To all, I have a Neptune TL washer that goes through the wash cycle normally. The problem arises with the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Neptune TL Washer does not spin dc code on LED screen
  #1 (permalink)
Old 11-08-2010, 07:07 AM
Junior Member
Rardo is on a distinguished road
Default Neptune TL Washer does not spin dc code on LED screen
Model Number: FAV6800AWW   Brand: Maytag   Age: 1 - 5 years
To all,
I have a Neptune TL washer that goes through the wash cycle normally. The problem arises with the spin cycle. When the machine begins the spin cycle, the machine thumps the load to the left trying to balance the load.
It starts and stops a number of times, always thumping when it starts to spin and then it eventually stops with "dc" appearing on the LED screen.
I have emptied the wet clothes from the machine and activated the spin only cycle. With no clothes in the machine, the spin cycle completes and the water empties from the machine.
From the existing posts, I've noticed on the 9800 model a possible fix is either cleaning or replacing the clutch. I've clicked on the service manual link in the posts, but got a "page not found". I couldn't find the pages that the posts refer to.
Is there some troubleshooting I can perform to determine the true problem? Also, is there any way to get the pages from the service manual so that I can better understand the repair process.
I'm new to the site, so I apologize if I have not explained the problem in the correct format. If further information is required, please let me know.
Thanks,
Bob
Related Models
Maytag FAV6800AWW WASHER-TOP LOADING
Maytag FAV9800AWQ WASHER-TOP LOADING
Maytag FAV9800AWW WASHER-TOP LOADING
Frigidaire FAX050P7A1 Frigidaire/air Conditioner
Frigidaire FAX050P7A2 Frigidaire/air Conditioner
Frigidaire FAX050P7A3 Frigidaire/air Conditioner
Frigidaire FAX050P7A4 Frigidaire/air Conditioner
Frigidaire FAX050P7A5 Frigidaire/air Conditioner
Frigidaire FAX050P7A6 Frigidaire/air Conditioner
Frigidaire FAX050P7A7 Frigidaire/air Conditioner
Frigidaire FAX050P7A8 Frigidaire/air Conditioner
Frigidaire FAX050P7AENG1 Frigidaire/air Conditioner
Frigidaire FAX050P7AENG2 Frigidaire/air Conditioner
Frigidaire FAX050P7AENG3 Frigidaire/air Conditioner
Frigidaire FAX050P7AENG4 Frigidaire/air Conditioner
Frigidaire FAX050P7AENG5 Frigidaire/air Conditioner
Frigidaire FAX050P7AENG6 Frigidaire/air Conditioner
Frigidaire FAX050S7A11 ROOM AIR CONDITIONER
Frigidaire FAX050S7A12 ROOM AIR CONDITIONER
Frigidaire FAX050S7A13 ROOM AIR CONDITIONER
Frigidaire FAX050S7A14 ROOM AIR CONDITIONER
Frigidaire FAX050S7A15 ROOM AIR CONDITIONER
Frigidaire FAX050S7A16 ROOM AIR CONDITIONER
Frigidaire FAX050S7A17 ROOM AIR CONDITIONER
Frigidaire FAX050S7AA ROOM AIR CONDITIONER
Frigidaire FAX050S7AB ROOM AIR CONDITIONER
Frigidaire FAX050S7AC ROOM AIR CONDITIONER
Frigidaire FAX050S7AD ROOM AIR CONDITIONER
Frigidaire FAX050S7AE ROOM AIR CONDITIONER
Frigidaire FAX050S7AF ROOM AIR CONDITIONER
Frigidaire FAX051P7A1 Frigidaire/air Conditioner
Frigidaire FAX051P7A2 Frigidaire/air Conditioner
Frigidaire FAX051P7A3 Frigidaire/air Conditioner
Frigidaire FAX051P7A4 Frigidaire/air Conditioner
Frigidaire FAX051P7A5 Frigidaire/air Conditioner
Frigidaire FAX051P7A6 Frigidaire/air Conditioner
Frigidaire FAX052P7A1 Frigidaire/air Conditioner
Frigidaire FAX052P7A11 ROOM A/C
Frigidaire FAX052P7A12 ROOM A/C
Frigidaire FAX052P7A13 ROOM A/C
Frigidaire FAX052P7A14 ROOM A/C
Frigidaire FAX052P7A15 ROOM A/C
Frigidaire FAX052P7A16 ROOM A/C
Frigidaire FAX052P7A2 Frigidaire/air Conditioner
Frigidaire FAX052P7A3 Frigidaire/air Conditioner
Frigidaire FAX052P7A4 Frigidaire/air Conditioner
Frigidaire FAX052P7A5 Frigidaire/air Conditioner
Frigidaire FAX052P7A6 Frigidaire/air Conditioner
Frigidaire FAX052P7AA ROOM A/C
Frigidaire FAX052P7AB ROOM A/C
Frigidaire FAX052P7AC ROOM A/C
Frigidaire FAX052P7AD ROOM A/C
Frigidaire FAX052P7AENG1 Frigidaire/air Conditioner
Frigidaire FAX052P7AENG2 Frigidaire/air Conditioner
Frigidaire FAX052P7AENG3 Frigidaire/air Conditioner
Frigidaire FAX052P7AENG4 Frigidaire/air Conditioner
Frigidaire FAX052P7AENG5 Frigidaire/air Conditioner
Frigidaire FAX052P7AENG6 Frigidaire/air Conditioner
Frigidaire FAX054P7A1 Frigidaire/air Conditioner
Frigidaire FAX054P7A11 ROOM A/C
Frigidaire FAX054P7A12 ROOM A/C
Frigidaire FAX054P7A13 ROOM A/C
Frigidaire FAX054P7A14 ROOM A/C
Frigidaire FAX054P7A15 ROOM A/C
Frigidaire FAX054P7A16 ROOM A/C
Frigidaire FAX054P7A2 Frigidaire/air Conditioner
Frigidaire FAX054P7A3 Frigidaire/air Conditioner
Frigidaire FAX054P7A4 Frigidaire/air Conditioner
Frigidaire FAX054P7A5 Frigidaire/air Conditioner
Frigidaire FAX054P7A6 Frigidaire/air Conditioner
Frigidaire FAX054P7AA ROOM A/C
Frigidaire FAX054P7AB ROOM A/C
Frigidaire FAX054P7AC ROOM A/C
Frigidaire FAX054P7AD ROOM A/C
Frigidaire FAX054P7AENG1 Frigidaire/air Conditioner
Frigidaire FAX054P7AENG2 Frigidaire/air Conditioner
Frigidaire FAX054P7AENG3 Frigidaire/air Conditioner
Frigidaire FAX054P7AENG4 Frigidaire/air Conditioner
Frigidaire FAX054P7AENG5 Frigidaire/air Conditioner
Frigidaire FAX054P7AENG6 Frigidaire/air Conditioner
Frigidaire FAZ085S1AA ROOM A/C
Frigidaire FAZ085S1AB ROOM A/C
Frigidaire FAZ085S7AA ROOM A/C
Frigidaire FAZ085S7AB ROOM A/C
Frigidaire FAZ08ES1AA ROOM A/C
Frigidaire FAZ08ES1AB ROOM A/C
Frigidaire FAZ08HR1A1 Frigidaire/air Conditioner
Frigidaire FAZ08HS1A11 ROOM AIR CONDITIONER
Frigidaire FAZ08HS1A12 ROOM AIR CONDITIONER
Frigidaire FAZ08HS1A13 ROOM AIR CONDITIONER
Frigidaire FAZ08HS1A14 ROOM AIR CONDITIONER
Frigidaire FAZ08HS1A15 ROOM AIR CONDITIONER
Frigidaire FAZ08HS1A16 ROOM AIR CONDITIONER
Frigidaire FAZ08HS1AA ROOM AIR CONDITIONER
Frigidaire FAZ08HS1AB ROOM AIR CONDITIONER
Frigidaire FAZ105S1AA ROOM A/C
Frigidaire FAZ105S1AB ROOM A/C
Frigidaire FAZ125S1AA ROOM A/C
Frigidaire FAZ125S1AB ROOM A/C
Frigidaire FAZ12ES2AA ROOM A/C
Frigidaire FAZ12ES2AB ROOM A/C
Frigidaire FAZ12HR2A2 Frigidaire/air Conditioner
Frigidaire FAZ12HS2A11 ROOM AIR CONDITIONER
Frigidaire FAZ12HS2A12 ROOM AIR CONDITIONER
Frigidaire FAZ12HS2A13 ROOM AIR CONDITIONER
Frigidaire FAZ12HS2AA ROOM AIR CONDITIONER
Frigidaire FAZ12HS2AB ROOM AIR CONDITIONER
Maytag FB10 DISPOSAL
Maytag FB11 DISPOSAL
Maytag FB20 DISPOSAL
Maytag FB21 DISPOSAL
Amana FB2221N WASHER-TOP LOADING
Amana FB7111N WASHER-TOP LOADING
Amana FB7221N WASHER-TOP LOADING
Whirlpool FB7700XR0 Floor care*
Whirlpool FB7700XS0 Floor care*
Whirlpool FB7700XS1 Floor care*
Whirlpool FB9900XR0 Floor care*
Whirlpool FB9900XS0 Floor care*
Frigidaire FBD2400KB0 DISHWASHER
  #2 (permalink)
Old 11-08-2010, 07:38 AM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
It may be helpful to remove the front panel, place a load of towels in and fill it with water; and watch it as it goes through a cycle. You may see just what is happening with the tub and suspensiion, as the vibration begins. There are two clips, One on each fo the front top corners of the panel. As you lift the top, depress each clip with a putty knife, or similar tool to release the top. It will hinge back to expose the other fasteners that hold the front panel in place. Once the panel is off, set it aside and let the top back down. There will be a lot more play in the cabinet without the front panel, but the machine will operate as designed, so you can observe it in action.
  #3 (permalink)
Old 11-08-2010, 08:55 AM
Senior Member
dh1200s is on a distinguished road
Default
Bob.
Your info is great and if you want to DIY the fix I will help you save the machine. Have you read thru this post Maytag Neptune load unbalance?
You are describing a Classic Clutch malfunction of a poor Maytag Clutch design.
The One-Way Roller clutches are not locking up (they slip) in Spin Cycle causing some agitator shaft rotation during wash basket spin up – CCW rotation of the Clutch Pulley/Wash Basket.
The tumblers rotate and drag the wash load off balance and after 4 or so attempts to redistribute the wash basket load the Control Board says enough of this crap and extends a dc or UC unbalance error. If your TDS was not working properly the machine would shake itself apart.
The SM is handy but servicematters.com has stopped access to the FAV6800A/FAV9800A Service Manual. I personally feel with the extremely poor Clutch and Tub Seal design of this machine series that Whirlpool/Maytag should be tarred and feathered or at least release the SM to us.
Anyway as an owner I will help you DIY the fix if after reading Maytag Neptune load unbalance you want go in that direction.
If you e-mail me (my vcard has that info click on my handle and view my public profile) I will send you some info to support the repair.
Good Luck………Dick
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
LR code: Neptune washer HELP terry67 Washer Repair 7 07-22-2010 11:22 AM
LR code: Neptune washer HELP terry67 Washer Repair 0 07-20-2010 10:21 PM
LR code: Neptune washer HELP terry67 Washer Repair 0 07-20-2010 10:15 PM
ND Error Code for Neptune Washer Neptune-ND Washer Repair 3 03-16-2010 04:47 AM
Maytag Neptune washer does not spin chilisastry Washer Repair 1 03-19-2009 08:46 PM
