Discuss
KitchenAid washer will not spin
 in
Washer Repair
My kitchenaid washer will not spin. I assume I had an uneven load yesterday. When I got home the washer
Appliance Repair Forum > Appliance Repair Help > Washer Repair » KitchenAid washer will not spin
  #1 (permalink)
Old 10-02-2007, 08:59 AM
calgal calgal is offline
Junior Member
calgal is on a distinguished road
Smile KitchenAid washer will not spin
Model Number: KAWE670BALO   Brand: Kitchen Aid   Age: More than 10 years
My kitchenaid washer will not spin. I assume I had an uneven load yesterday. When I got home the washer had moved sideways. The rug inside was still soaking wet. When I run the spin cycle I can hear water being sucked out of the machine, but the tub does not spin. Under the washer I can see rubber shavings. I have removed the back panel, but I can't seem to but my finger on what is wrong. Can any one help me and tell me which part I need to replace?
Thanks for your assistance
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-02-2007, 07:07 PM
Junior Member
Wink Fixed
I was able to do more research and determined that the motor coupler was shot and needed to be replaced. Found the part and replaced today. I am running a cycle right now to see if it works properly. Currently in the rinse cycle so it did spin at least once. Think I have it fixed. Wasn't to hard to do either for this California gal! The part was $15.95 at my local parts store.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
my washer won't spin jopas213 Washer Repair 8 10-23-2008 01:03 PM
washer will not spin chevy2 Washer Repair 6 03-10-2008 01:47 PM
KitchenAid washer won't spin Sherry Washer Repair 3 03-06-2008 04:48 PM
Washer will not spin Darren Washer Repair 4 10-26-2007 02:41 PM
Washer won't spin arnoldte Washer Repair 1 09-19-2007 10:04 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
