Unit will not spin after complete rinse cycle. unit washes fine and rinses. wife runs unit in wash mode again to get rid of water before the rinnse cycle comes on again
Groups: Expert
Joined: 7/27/2010(UTC) Posts: 1,395 Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
Originally Posted by: leroy.grulke Unit will not spin after complete rinse cycle. unit washes fine and rinses. wife runs unit in wash mode again to get rid of water before the rinnse cycle comes on again Are you sure its spinning in the rise cycle? If so it could be the timer or the lid switch. Make sure the lid switch is working. Does it do the same thing during different cycles?
Sorry; It spins at the end of the wash cycle only. It fills to rinse and goes through the rinse cycle but does not engage for the final spin at the end of the rinse cycle.
However, the "Dial" continues to proceed as if engaged till it reaches "Off".
