when you pull the knob to start the washer the cold water will not start. if you put it on hot water it will start filling but water willpour into the floor from under neath the washer.any ideas
Well this is somewhat of a mystery. I would first take off the front of the cabinet and see if you can determine where the leak is coming from. Fix that and then see what happens.
