| » Maytag F1 error |
Model Number: MTW6600tQ0 Brand: Maytag Age: 1 - 5 years
Maytag washer will stop cycle within first min and flash F1 error. Have to hit pause and change cycle and it will run until min 21. Will hit pause again and wait and it will run. Any advice on what this issue is and how it can be repaired?
Quote:
Bob, The F1 code indicates that the main control board is not seeing a change in the water level. You need to check: The air dome hose(the clear plastic tube that goes down to the side of the tub) for clogs, kinks and tight fit at both ends. You need to check the wire harness, and connections at the motor RPS sensor (motor) and control board. If the airdome hose and attachment points are OK, my first guess would be the harness and wires to the RPS / Motor assembly, Part number: AP4327312 From there it would be the main control board in the control panel, Part number: AP4360738 You should be able to raise the top panel (using a putty knife to release the clips holding the top down, and find your Technical Data Sheet attached to the front panel interior, that way you can run the diagnostics and failure codes, etc. Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Maytag oven with F3 error | Teresa | Oven Repair (including Ranges and Cooktops) | 2 | 02-08-2011 12:51 PM |
| maytag neptune - nd error | Rich Gassett | Washer Repair | 9 | 10-16-2010 12:36 PM |
| nd error maytag | smoothboarr | Washer Repair | 1 | 08-09-2010 06:45 PM |
| 1E Maytag Washer Error | Armani | Washer Repair | 6 | 10-05-2008 02:15 PM |
| Maytag oven F7 error | ratflinger | Oven Repair (including Ranges and Cooktops) | 3 | 04-11-2008 09:08 PM |
