control shut down
When power button is pushed washer control powers up. When start button is pushed door locks but then unlocks after less than 10 seconds and control powers off. If selector is set to drain and spin it works normally for that cycle.Ran auto diagnostic test and all system worked as needed.One fault code of F24 was stored. This code is for the heat sensor or heater. This machine is not equiped with a heater. Replaced CCU but problem persists. Any help?
| All times are GMT -7. The time now is 06:42 PM. |
