wannnabetech
#1 Posted : Tuesday, October 28, 2008 10:01:25 AM(UTC)
wannnabetech
f-14 error code came on so i changed ccu. I put in new ccu now fh error code is on. Tested everything and checked out fine. Washer does not have flow meter. can this be the cause of fh code? If so did i get the wrong ccu.
libertyappl
#2 Posted : Tuesday, October 28, 2008 10:25:26 AM(UTC)
libertyappl
Chec the water valve the FH code means there's no water getting into the unit.
Nat
wannnabetech
#3 Posted : Tuesday, October 28, 2008 4:34:21 PM(UTC)
wannnabetech
sorry forgot to add that water goes into washer and after about 30 sec code comes on
Whirlpool Duet washer FH code (Washer Repair)
by farmgirl 1/17/2017 7:14:25 PM(UTC)
fh code on whirlpool duet (Washer Repair)
by keithdouglas 3/5/2016 11:56:19 AM(UTC)
Whirlpool Duet GHW9250 FH code (Washer Repair)
by duanec 7/7/2013 6:03:46 PM(UTC)
by Dove 7/14/2012 6:35:16 AM(UTC)
Maytag front loader FH code (Washer Repair)
by tamiwalnut 1/28/2010 1:42:29 PM(UTC)
Fh Code (Washer Repair)
by GWILLIAMS 10/16/2009 7:53:28 AM(UTC)
Fh Code No Or Insufficient Water Supply (Washer Repair)
by meeksj 6/20/2009 9:01:06 PM(UTC)
Kenmore HE3 FH code early in cycle (Washer Repair)
by st_pinetree 2/6/2009 7:10:22 AM(UTC)
Duet Washer displays FH code (Washer Repair)
by kaahurley 6/20/2008 7:37:24 AM(UTC)
