Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   maytag neptune tl (http://forum.appliancepartspros.com/washer-repair/135415-maytag-neptune-tl.html)
rawhide 007 10-25-2010 02:53 PM
maytag neptune tl
we have a OP code on the washer it will not let us proceed to locking the lid what do we to fix it.
rawhide
dh1200s 10-25-2010 03:25 PM
3 Attachment(s)
Quote:
rawhide
Hey rawhide, I’m an owner and do all my own work on the machine. Most times this issue is caused by loss of signaling thru the Left Hand Lid Lock.
1st check for a Lid Magnet out of position. This is an easy check if you have a couple key holder magnets or a similar magnet that you can place over the Left side grey lid bumper. Let’s see if you can close the Magnetic Reed Relay switch with an external magnet and send +12VDC up to the Control Board and clear the “OP” error code.
If that doesn’t clear the “OP” error code we will need to remove the Left Hand Lid Lock and check to see if corrosion is part of the issue. Because of its proximity to that nasty bleach dispenser it will cause issues.
See the 2nd and 3rd pic’s.
If you are going to DIY you will need the Service Manual for support if so e-mail me, My V-Card has my e-mail adr............Dick
rawhide 007 10-25-2010 05:16 PM
need e-mail address
Dick: I am not able to find your v-card for e-mailing you
rawhide pleasee-mail rll53@woh.rr.com
dh1200s 10-25-2010 07:37 PM
rawhide I sent you some info. Let's see if the external magnet will clear the OP error code. If not we will move to the next level of troubleshooting. Dick
