Discuss
MAV8551AWW COLD WATER setting issue
 in
Washer Repair
Problem started when washing machine is set to a cold water setting, water filling tub comes out VERY slowly and
Appliance Repair Forum > Appliance Repair Help > Washer Repair » MAV8551AWW COLD WATER setting issue
  #1 (permalink)
Old 10-23-2010, 04:55 PM
Junior Member
andyjmatthews is on a distinguished road
Default MAV8551AWW COLD WATER setting issue
Model Number: MAV8851AWW   Brand: Maytag   Age: 1 - 5 years
Problem started when washing machine is set to a cold water setting, water filling tub comes out VERY slowly and a humming cab be heard. Warm and Hot water appear to come out fine, but would say that the Warm setting is hotter then normal since cold isn't dispensing properly. Could this be a water inlet value issue or something else? Any assistance would be greatly appreciate and if you know what the issue is, please provide parts model number. Thanks
Ads By Google
Related Models
Maytag MAV9501EWQ Washer, Atlantis
Maytag MAV9501EWW Washer, Atlantis
Maytag MAV9504EWQ Washer, Atlantis
Maytag MAV9504EWW Washer, Atlantis
Maytag MAV9557EWQ Washer, Atlantis
Maytag MAV9557EWW Washer, Atlantis
Maytag MAV9600EWQ Washer, Atlantis
Maytag MAV9600EWW Washer, Atlantis
Maytag MAV9657EWQ Washer, Atlantis
Maytag MAV9657EWW Washer, Atlantis
Maytag MAV9750AGW Washer, Atlantis
Maytag MAV9750AWQ Washer, Atlantis
Maytag MAV9750AWW Washer, Atlantis
Maytag MAVT236AWW Washer - Top Loading
Maytag MAVT346AWW Washer - Top Loading
Maytag MAVT446AWW Washer - Top Loading
Maytag MAVT546EWW Washer - Top Loading
Maytag MAVT634AWW Washer, Atlantis
Maytag MAVT734EWW Washer, Atlantis
Maytag MAVT754EWW Washer, Atlantis
Maytag MAVT834AWQ Washer, Atlantis
Maytag MAVT834AWW Washer, Atlantis
Whirlpool MB1110SLQ Microwave Oven 1.1 Cubic Foot
International MB1927PEHB  Ref - Maytag Int'l Bot Mount
International MB1927PEHW  Ref - Maytag Int'l Bot Mount
International MB2216PUAW Ref - Bottom Mounts
International MB2227PEHB  Ref - Maytag Int'l Bot Mount
International MB2227PEHW  Ref - Maytag Int'l Bot Mount
Thermador MB245
General Electric MB536BB1 Electric range
Whirlpool MB7120XYB0
Whirlpool MB7120XYB1
General Electric MB757WB1 Electric range
Maytag MBB1952GRQ  Ref - Bottom Mounts
Maytag MBB1952GRW  Ref - Bottom Mounts
Maytag MBB1952HEB Ref - Bottom Mounts
Maytag MBB1952HEQ Ref - Bottom Mounts
Maytag MBB1952HEW Ref - Bottom Mounts
Maytag MBB1954GEB  Ref - Bottom Mounts
Maytag MBB1954GEQ  Ref - Bottom Mounts
Maytag MBB1954GES  Ref - Bottom Mounts
Maytag MBB1954GEW  Ref - Bottom Mounts
Maytag MBB1954HEW Ref - Bottom Mounts
Maytag MBB1956GEB  Ref - Bottom Mounts
Maytag MBB1956GEQ  Ref - Bottom Mounts
Maytag MBB1956GES  Ref - Bottom Mounts
Maytag MBB1956GEW  Refrigerator
Maytag MBB1956HEB Ref - Bottom Mounts
Maytag MBB1956HEQ Ref - Bottom Mounts
Maytag MBB1956HES Ref - Bottom Mounts
Maytag MBB1956HEW Ref - Bottom Mounts
Maytag MBB2254GEB  Ref - Bottom Mounts
Maytag MBB2254GEQ  Ref - Bottom Mounts
Maytag MBB2254GES  Ref - Bottom Mounts
Maytag MBB2254GEW  Ref - Bottom Mounts
Maytag MBB2256GEB  Ref - Bottom Mounts
Maytag MBB2256GEQ  Ref - Bottom Mounts
Maytag MBB2256GES  Ref - Bottom Mounts
Maytag MBB2256GEW  Ref - Bottom Mounts
Maytag MBF1956HEB Ref - Bottom Mounts
Maytag MBF1956HEQ Ref - Bottom Mounts
Maytag MBF1956HES Ref - Bottom Mounts
Maytag MBF1956HEW Ref - Bottom Mounts
Maytag MBF1956KEB Ref - Bottom Mounts
Maytag MBF1956KEQ Ref - Bottom Mounts
Maytag MBF1956KEW Ref - Bottom Mounts
Maytag MBF2254HEB Ref - Bottom Mounts
Maytag MBF2254HEB14 Refrigerator
Maytag MBF2254HEQ Ref - Bottom Mounts
Maytag MBF2254HEQ14 Refrigerator
Maytag MBF2254HES White Westinghouse/refrigerator
Maytag MBF2254HEW Ref - Bottom Mounts
Maytag MBF2254HEW14 Refrigerator
Maytag MBF2255KEB Ref - Bottom Mounts
Maytag MBF2255KEB11 Refrigerator
Maytag MBF2255KEQ Ref - Bottom Mounts
Maytag MBF2255KEQ11 Refrigerator
Maytag MBF2255KEW Ref - Bottom Mounts
Maytag MBF2255KEW11 Refrigerator
Maytag MBF2256HEB Ref - Bottom Mounts
Maytag MBF2256HEQ Ref - Bottom Mounts
Maytag MBF2256HES Ref - Bottom Mounts
Maytag MBF2256HEW Ref - Bottom Mounts
Maytag MBF2256KEB Ref - Bottom Mounts
Maytag MBF2256KEB11 Refrigerator
Maytag MBF2256KEQ Ref - Bottom Mounts
Maytag MBF2256KEQ11 Refrigerator
Maytag MBF2256KEW Ref - Bottom Mounts
Maytag MBF2256KEW11 Refrigerator
Maytag MBF2258HEB Ref - Bottom Mounts
Maytag MBF2258HEQ Ref - Bottom Mounts
Maytag MBF2258HES Ref - Bottom Mounts
Maytag MBF2258HEW Ref - Bottom Mounts
Maytag MBF2262HEB Ref - Bottom Mounts
Maytag MBF2262HEB13 Refrigerator
Maytag MBF2262HEQ Ref - Bottom Mounts
Maytag MBF2262HEW Ref - Bottom Mounts
Maytag MBF2262HEW13 Refrigerator
Maytag MBF2556HEB Ref - Bottom Mounts
Maytag MBF2556HEQ Ref - Bottom Mounts
Maytag MBF2556HES Ref - Bottom Mounts
Maytag MBF2556HEW Ref - Bottom Mounts
Maytag MBF2556HSW Ref - Bottom Mounts
Maytag MBF2556KEB Ref - Bottom Mounts
Maytag MBF2556KEQ Ref - Bottom Mounts
Maytag MBF2556KEW Ref - Bottom Mounts
Maytag MBF2558HEB Ref - Bottom Mounts
Maytag MBF2558HEQ Ref - Bottom Mounts
Maytag MBF2558HES Ref - Bottom Mounts
Maytag MBF2558HEW Ref - Bottom Mounts
Maytag MBF2562HEB Ref - Bottom Mounts
Maytag MBF2562HEQ Ref - Bottom Mounts
Maytag MBF2562HEW Ref - Bottom Mounts
Maytag MBL1952KES Ref - Bottom Mounts
Maytag MBL1956HES Ref - Bottom Mounts
Maytag MBL1956KES Ref - Bottom Mounts
Maytag MBL2255KES Ref - Bottom Mounts
Maytag MBL2255KES12 Refrigerator
Maytag MBL2256KES Ref - Bottom Mounts
Maytag MBL2256KES12 Refrigerator
  #2 (permalink)
Old 10-24-2010, 03:34 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Here are your parts.
Replacement parts for MAV8851AWW models | AppliancePartsPros.com
Turn off the tap and remove the cold water hose at the machine.
Run the cold water into a pail to see if you have adequate flow.
If flow is low
Some hoses have a screen filter built into the seal at the tap end. Check to see if this is there and clogged.
Also hoses can de-laminate internally and restrict the flow. If this is the case replace the hose.
If flow is OK
Take a look into the water valve on the machine.
Valves have a built in screen filter on their input side. Perhaps this is clogged up. If it is clean it.
Do not permanently remove it from the valve as it is there to keep crud out of the valve which could hold the valve open and cause a flood.
If all the above are OK then odds are that the valve needs replacing.
__________________
  #3 (permalink)
Old 10-24-2010, 07:24 AM
Junior Member
Default
Thank you very much for the advise, worked like a charm. I have well water and the screen/filter entering the valve had become very blocked with sediment/rock chips. Once I flushed this screen out, reconnected the hose, cold water flow was back to normal. Thank you again, you saved me $$$ by not having to call a repair service.
  #4 (permalink)
Old 10-24-2010, 09:13 AM
Senior Expert
APP Volunteer
Default
You are welcome
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Water Temp hot regardless of setting Global Kiss Washer Repair 1 09-01-2009 06:11 PM
washer won"t run on cold cold water setting jwh4969 Washer Repair 1 12-23-2008 06:41 AM
GE refrigerator wont get cold even on the coldest setting athomemom Refrigerator & Freezer Repair 5 11-13-2008 09:34 PM
inside of fridge temprature to cold on lowest setting. LSobo Refrigerator & Freezer Repair 1 08-28-2008 04:09 PM
Water level low on each setting dogdent Washer Repair 0 03-05-2008 04:53 PM
