chiefs
#1 Posted : Saturday, October 23, 2010 10:38:28 AM(UTC)
chiefs
This washer has its own diagnostics which i ran and got code e52 which is bad signal from tacho generator.
I performed test on pins 4 and 5 on motor and got recommended 130 ohms and it says replace speed control board, if not replace motor.
i replace the white plastic board in bottom of machine that plugs into motor .....is this the right board????? because the machine does the same thing ......which is shuts off after about 10 minutes and the start button flashes like it has reset itself.
Hate to keep buying good parts.
sidfink43
#2 Posted : Monday, October 25, 2010 6:55:15 AM(UTC)
sidfink43
Boy I wish I could give you good news, but you have come up against the problem with computer controls and diagnostic systems. The problem is these machines have electronics which regularly fail and which regularly do not give good diagnostic info.
It seems like your motor is ok, and the problem is not in the speed control board, so it can be the main control board, door lock mechanism or wiring between all of those components. I would start by checking the wiring.
Here is a service manual, good luck, but you may just end up replacing parts until you get it fixed (that what techs do with these models) If you buy parts from this site and they do not fix things you can return them.
See returns policy for requirements
http://frigidaireservicetips.co...rizontalAxisWasherSM.pdf
chiefs
#3 Posted : Monday, October 25, 2010 10:41:22 AM(UTC)
chiefs
ok.....Yes i purchased it here i will see about returning.....
I was leaning towards it being the motor........
update here.....i found the large wheel on back of tub that has the belt on it slightly loose ......to where when the motor switched directions it would slip .....maybe a quarter of an inch......tightened and ran washer at least 12 or more times and ran just fine......then it happeded again....im going crazy.....:)
sidfink43
#4 Posted : Monday, October 25, 2010 10:46:34 AM(UTC)
sidfink43
Okay, the error that you are getting is related to a tachometer that measures the speed of the motor. If your belt is slipping sometimes, it may be that it is slowing down the speed of the motor to the point that it triggers the shutdown and the error message.
Have not had a problem with a loose belt on these, so look at the manual and see if there is a way to fix things.
chiefs
#5 Posted : Monday, October 25, 2010 11:25:38 AM(UTC)
chiefs
i have the wheel tight now.......no slippage....but the belt does seem squeak a little when reversing directions.....maybe just a belt???
sidfink43
#6 Posted : Monday, October 25, 2010 11:33:07 AM(UTC)
sidfink43
Good idea, the pulley is not adjustable so the belt may be stretched.
RyanWade
#7 Posted : Friday, November 2, 2012 8:03:48 PM(UTC)
RyanWade
I got the siame error code on my washer. I cleaned out the drain hose due to the washer no spinning, tried again same problem. While I had the back off I noticed that the drum would stick sometimes when turning it by hand. I can turn past the spot when it sticks but it will stick again. Any Ideas on this one? Is this probably a problem with the motor?
Frigidaire washer will not fill. (Washer Repair)
by Elwood44 8/24/2021 12:55:10 PM(UTC)
Frigidaire Washer FWT449GFS1 won't start or fill will water just makes humming sound (Washer Repair)
by lizard2000 7/6/2021 4:27:51 PM(UTC)
Frigidaire Washer Dryer Combo GLET1142CS0 (Washer Repair)
by texashuman 11/16/2020 9:17:08 AM(UTC)
frigidaire washer not spinning out clothes (Washer Repair)
by tadthebass 3/24/2020 8:51:55 AM(UTC)
Frigidaire washer not draining, no high speed spin (Washer Repair)
by Stheemka 3/24/2020 6:39:56 AM(UTC)
Frigidaire Washer FAFW3801LW3 - Just replaced the control board. Washer won't start the cycle. (Washer Repair)
by johnnyboy101 10/4/2019 11:31:42 AM(UTC)
Frigidaire Washer Dryer Combo Not Working (Washer Repair)
by soshea42 7/10/2016 4:10:09 PM(UTC)
Frigidaire washer dispenser magnet (Washer Repair)
by JAbraham 1/19/2016 12:05:33 PM(UTC)
Frigidaire washer won't agitate (Washer Repair)
by goosemasterkl 8/15/2015 9:37:13 AM(UTC)
Frigidaire Washer - No agitation and no spin (Washer Repair)
by jmplsjones 6/29/2015 7:30:44 AM(UTC)
Frigidaire Washer error code 31 (Washer Repair)
by tilegods 5/1/2015 4:15:19 AM(UTC)
Frigidaire Washer will not spin (Washer Repair)
by luvmylars 4/30/2015 11:33:25 AM(UTC)
Frigidaire washer - loud screeching noise at start of spin cycle (Washer Repair)
by Shrimpzilla 4/8/2015 10:25:33 AM(UTC)
Frigidaire Washer "Unique" Leak? (Washer Repair)
by randynavarro 1/3/2015 7:11:35 AM(UTC)
frigidaire washer turns on by itself and floods floor (Washer Repair)
by justin r 12/31/2014 12:32:12 PM(UTC)
