Discuss
Maytag Atlantis won't spin at full speed
 in
Washer Repair
Once it get's to the spin cycle it makes a slight squeaking noise and I can smell a burnt
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Atlantis won't spin at full speed
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 09-29-2007, 10:43 PM
datafortress datafortress is offline
Junior Member
datafortress is on a distinguished road
Question Maytag Atlantis won't spin at full speed
Model Number: MAV6200AWW   Brand: Maytag   Age: 1 - 5 years
Once it get's to the spin cycle it makes a slight squeaking noise and I can smell a burnt rubber odour.
It will only spin enough to trickle out of the drain pipe and throw the water over the edge of the drum to flood the floor.
If I pull the timer switch in and out rapidly several times in a row, which I have to do twice per load, it will eventually start into it's proper spin cycle. (very annoying if I miss it)
The problem is intermittent and it will sometimes spin properly for either the 1st or 2nd spin. (once every 10 loads or so)
I'm thinking timer problem but thought I would check with the pros on here first.
Any suggestions?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-03-2007, 01:22 AM
Junior Member
Default
Any ideas at all folks?
  #3 (permalink)
Old 10-03-2007, 03:44 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
I would pull your front panel and check your pump for a clog. If ok. I would check your belt for wear, then pull it off and check your tranny pulley, turn it one way then the next. If hard to turn in spin, you might have something caught in the tub. You can shine a light in the spin basket and look in the tub.
If everything ok, turn the tranny pulley in spin direction and watch the pulley turn up and disengage the brake. If this doesn't happen you will need a pulley/cam kit.
Go to Appliance repairs, Appliancehelp, Appliances, repairs to dryers washers dishwashers fridges repairs microwaves ge maytag kenmore frigidaire westinghouse inglis, appliance how to take apart information, purchasing an appliance help, model number help, for info. You can order your parts by clicking on your model # above.
__________________
  #4 (permalink)
Old 01-13-2008, 10:00 PM
Junior Member
Default
I finally got around to looking at the washer and it wasn't the belt or the pulley. The drive motor is mounted on a sliding assembly with nylon bushings which moves it left or right depending on which cycle is running. The track and bushings were full of caked on gunk and rust preventing the motor from sliding all the way and tightening the tension on the belt for the spin cycle and also stopping the waterpump from spinning properly. I removed the motor and mounting bracket and cleaned/scraped all the gunk from the bracket. I cleaned the motor with air from my compressor. I then hit the bracket with a coat of Tremclad, cleaned all the nylon bushings and then re-assembled. I put a touch of bearing grease on the track and the machine now runs like new. It didn't cost me anything except time.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Top agitater doesn't work on full load angiebrown85 Washer Repair 0 09-28-2007 05:48 AM
Maytag Atlantis overflows - wont agitate Woody Washer Repair 4 08-27-2007 03:11 PM
Tub full of water Don Jr. Washer Repair 0 08-10-2007 06:52 AM
Only 1 fan speed / Unit turns itself off KenK Heating, Ventilation, and Air Conditioning (HVAC) 0 08-09-2007 08:25 AM
only one speed GaleR General Talk 2 08-03-2007 11:43 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
