| » Wash Cycle Slow, Wont Spin,But water is pumped out |
Model Number: LWD35AW Brand: Amana Age: 5 - 10 years
during wash cycle it agitates very slow, when it reaches spin cycle, agitator stops, but water is expelled from hose..timer was replaced 4yrs ago to correct a no spin no water eject problem and has worked flawlessly until now...
Well if this here washer pumps out then the lid switch is ok, I would be willing to bet you have a bad belt. It is easy to replace IF you remove the motor and pump assembly from the washer and replace the belt then re- install that assembly. The pump needs stardrive screwdriver by the way and I THINK you remove 4 bolts to get that motor and pump assembly out after removing the front panel. The motor has a quick plug so no wiring to worry about. Make a note of how that belt goes between the pump. If ye ferget then ye will cuss.
| Display Modes | |
| kenmore front load washer very slow spin cycle won,t extract water | randyb.2 | Washer Repair | 5 | 11-07-2010 03:07 PM |
| Spin cycle slow | Ozz | Washer Repair | 2 | 01-01-2010 01:36 PM |
| Slow spin cycle and wobbles with load | stevek1959 | Washer Repair | 1 | 07-15-2009 12:28 PM |
| whirlpool runs but the spin cycle really slow | allen9258 | Washer Repair | 3 | 01-14-2009 02:29 AM |
| Maytag wash won't spin on regular cycle but will on gentle cycle | BlazingSun | Washer Repair | 0 | 01-07-2009 08:41 PM |
