davyboy
#1 Posted : Friday, October 24, 2008 1:22:08 PM(UTC)
davyboy
Heard a grinding/rattling sound coming from washer. Drum did not drain in rinse cycle. I took the pump apart and found that the prop fell off the pump shaft. I reassembled it and ran it thru a cycle. Washer drained in the wash and first rinse cycle but did not drain after that. I removed the pump again and it was very hot. I am figuring this is probably the pump so I ordered one today. Do you think that it might be the pump?
Thank you very much
libertyappl
#2 Posted : Friday, October 24, 2008 7:54:50 PM(UTC)
libertyappl
Sounds like the pump to me.
Nat
How does Whirlpool agitate? (Washer Repair)
by Alex Pabloroux 4/12/2024 1:40:40 PM(UTC)
Whirlpool WRS325FDAM04 (Refrigerator & Freezer Repair)
by nhred71 4/11/2024 10:32:03 AM(UTC)
Whirlpool Ice Dispenser Auger will not run (Refrigerator & Freezer Repair)
by WhirlpoolDave 4/1/2024 12:44:26 PM(UTC)
Whirlpool Duet MDL# WWF8400TW02 New Drain Pump (Washer Repair)
by 1Oskydoodle! 3/30/2024 10:30:29 AM(UTC)
Whirlpool ler5635lq0 timer issue (Dryer Repair)
by Rolandtd 3/26/2024 6:15:44 AM(UTC)
Whirlpool WFW5620HW3 F6E3 Error (Washer Repair)
by hunt_ak 3/25/2024 12:55:01 PM(UTC)
Whirlpool Oven - Controls Don't Work (Oven Repair (including Ranges and Cooktops))
by Guest 3/25/2024 10:18:22 AM(UTC)
Kenmore/Whirlpool GB22DKXJW00 - evap fan replacement no ground (Refrigerator & Freezer Repair)
by DIY2024 3/24/2024 1:07:07 AM(UTC)
Multiple failures in Whirlpool oven? (Oven Repair (including Ranges and Cooktops))
by Guest 3/22/2024 6:55:50 AM(UTC)
whirlpool range GS395LEG (Oven Repair (including Ranges and Cooktops))
by Guest 3/18/2024 12:17:23 PM(UTC)
Whirlpool WRF757SDEM01 led light problem (Refrigerator & Freezer Repair)
by Guest 3/16/2024 1:02:12 PM(UTC)
Whirlpool WRS325SDHB08 Icemaker works intermittently (Refrigerator & Freezer Repair)
by donl1150 3/2/2024 5:04:55 AM(UTC)
Whirlpool Quiet Partner II Repair (Dishwasher Repair)
by Scubacrazy56 3/1/2024 7:54:50 AM(UTC)
Automatic water filter bypass - Whirlpool Refrigerator GD5SHAXLQ02 (Refrigerator & Freezer Repair)
by z-vap 2/28/2024 2:08:23 PM(UTC)
Whirlpool Gold GD5SHA Freezer Temperature Rises Overnight (Refrigerator & Freezer Repair)
by jrb98391 2/22/2024 10:20:17 AM(UTC)
