Discuss
motor turns easily when I pull belt, but fault code manual says to remove belt first
 in
Washer Repair
Fault code E57 says to see if motor turns freely with belt removed....being lazy and trying to beat the system
Appliance Repair Forum > Appliance Repair Help > Washer Repair » motor turns easily when I pull belt, but fault code manual says to remove belt first
  #1 (permalink)
Old 10-21-2010, 06:58 AM
Junior Member
kenrepair is on a distinguished road
Default motor turns easily when I pull belt, but fault code manual says to remove belt first
Model Number: glft2940fs1   Brand: Frigidaire   Age: 1 - 5 years
Fault code E57 says to see if motor turns freely with belt removed....being lazy and trying to beat the system (just being honest), I figured that with a machine only 22 months old...(I didn't buy the extended warranty) that if it turned at all, then the motor must be good. NO?
Related Models
Frigidaire GLFU1467FW0 Frigidaire/freezer
Frigidaire GLFU1467FW1 FREEZER
Frigidaire GLFU1467FW2 FREEZER
Frigidaire GLFU1767FW2 Frigidaire/freezer
Frigidaire GLFU1767FW3 Frigidaire/freezer
Frigidaire GLFU1767FW4 Frigidaire/freezer
Frigidaire GLFU1767FW5 FREEZER
Frigidaire GLFU1767FW6 FREEZER
Frigidaire GLFU2067FW2 Frigidaire/freezer
Frigidaire GLFU2067FW3 Frigidaire/freezer
Frigidaire GLFU2067FW4 Frigidaire/freezer
Frigidaire GLFU2067FW5 FREEZER
Frigidaire GLFU2067FW6 FREEZER
Frigidaire GLFU2067FW7 FREEZER
Frigidaire GLFU2067FW8 FREEZER
Frigidaire GLGC30S8ABA Frigidaire/cooktop
Frigidaire GLGC30S8ABB Frigidaire/gas Cooktop
Frigidaire GLGC30S8AQA Frigidaire/cooktop
Frigidaire GLGC30S8AQB Frigidaire/gas Cooktop
Frigidaire GLGC30S8ASA Frigidaire/cooktop
Frigidaire GLGC30S8ASB Frigidaire/gas Cooktop
Frigidaire GLGC30S8CBA Frigidaire/gas Cooktop
Frigidaire GLGC30S8CBB Frigidaire/gas Cooktop
Frigidaire GLGC30S8CQA Frigidaire/gas Cooktop
Frigidaire GLGC30S8CQB Frigidaire/gas Cooktop
Frigidaire GLGC30S8CSA Frigidaire/gas Cooktop
Frigidaire GLGC30S8CSB Frigidaire/gas Cooktop
Frigidaire GLGC30S8EBA Frigidaire/gas Cooktop
Frigidaire GLGC30S8EQA Frigidaire/gas Cooktop
Frigidaire GLGC30S8ESA Frigidaire/gas Cooktop
Frigidaire GLGC30S8KBA Frigidaire/gas Cooktop
Frigidaire GLGC30S8KBB Frigidaire/gas Cooktop
Frigidaire GLGC30S8KSA Frigidaire/gas Cooktop
Frigidaire GLGC30S8KSB Frigidaire/gas Cooktop
Frigidaire GLGC30S9EBA Frigidaire/gas Cooktop
Frigidaire GLGC30S9EQA Frigidaire/gas Cooktop
Frigidaire GLGC30S9ESA Frigidaire/gas Cooktop
Frigidaire GLGC36S8ABA Frigidaire/gas Cooktop
Frigidaire GLGC36S8ABB Frigidaire/gas Cooktop
Frigidaire GLGC36S8AQA Frigidaire/gas Cooktop
Frigidaire GLGC36S8AQB Frigidaire/gas Cooktop
Frigidaire GLGC36S8ASA Frigidaire/gas Cooktop
Frigidaire GLGC36S8ASB Frigidaire/gas Cooktop
Frigidaire GLGC36S8CBA Frigidaire/gas Cooktop
Frigidaire GLGC36S8CBB Frigidaire/gas Cooktop
Frigidaire GLGC36S8CQA Frigidaire/gas Cooktop
Frigidaire GLGC36S8CQB Frigidaire/gas Cooktop
Frigidaire GLGC36S8CSA Frigidaire/gas Cooktop
Frigidaire GLGC36S8CSB Frigidaire/gas Cooktop
Frigidaire GLGC36S8EBA Frigidaire/gas Cooktop
Frigidaire GLGC36S8EQA Frigidaire/gas Cooktop
Frigidaire GLGC36S8ESA Frigidaire/gas Cooktop
Frigidaire GLGC36S8KBA Frigidaire/gas Cooktop
Frigidaire GLGC36S8KSA Frigidaire/gas Cooktop
Frigidaire GLGC36S9EBA Frigidaire/gas Cooktop
Frigidaire GLGC36S9EQA Frigidaire/gas Cooktop
Frigidaire GLGC36S9ESA Frigidaire/gas Cooktop
Frigidaire GLGF366ABA Frigidaire/range
Frigidaire GLGF366ABB Frigidaire/range
Frigidaire GLGF366ABC Frigidaire/gas Range
Frigidaire GLGF366ABD Frigidaire/gas Range
Frigidaire GLGF366AQA Frigidaire/range
Frigidaire GLGF366AQB Frigidaire/range
Frigidaire GLGF366AQC Frigidaire/gas Range
Frigidaire GLGF366AQD Frigidaire/gas Range
Frigidaire GLGF366ASA Frigidaire/range
Frigidaire GLGF366ASB Frigidaire/range
Frigidaire GLGF366ASC Frigidaire/gas Range
Frigidaire GLGF366ASD Frigidaire/gas Range
Frigidaire GLGF376DBA Frigidaire/gas Range
Frigidaire GLGF376DBB Frigidaire/gas Range
Frigidaire GLGF376DBC Frigidaire/range
Frigidaire GLGF376DBE Frigidaire/range
Frigidaire GLGF376DBF Frigidaire/range
Frigidaire GLGF376DBG Frigidaire/range
Frigidaire GLGF376DBH Frigidaire/range
Frigidaire GLGF376DBJ GAS RANGE
Frigidaire GLGF376DBK GAS RANGE
Frigidaire GLGF376DBM GAS RANGE
Frigidaire GLGF376DBN GAS RANGE
Frigidaire GLGF376DBR GAS RANGE
Frigidaire GLGF376DCA Frigidaire/gas Range
Frigidaire GLGF376DCB Frigidaire/range
Frigidaire GLGF376DCC Frigidaire/range
Frigidaire GLGF376DCD Frigidaire/range
Frigidaire GLGF376DCF Frigidaire/range
Frigidaire GLGF376DQA Frigidaire/gas Range
Frigidaire GLGF376DQB Frigidaire/gas Range
Frigidaire GLGF376DQC Frigidaire/range
Frigidaire GLGF376DQE Frigidaire/range
Frigidaire GLGF376DQF Frigidaire/range
Frigidaire GLGF376DQG Frigidaire/range
Frigidaire GLGF376DQH Frigidaire/range
Frigidaire GLGF376DQJ GAS RANGE
Frigidaire GLGF376DQK GAS RANGE
Frigidaire GLGF376DQM GAS RANGE
Frigidaire GLGF376DSA Frigidaire/gas Range
Frigidaire GLGF376DSB Frigidaire/gas Range
Frigidaire GLGF376DSC Frigidaire/range
Frigidaire GLGF376DSE Frigidaire/range
Frigidaire GLGF376DSF Frigidaire/range
Frigidaire GLGF376DSG Frigidaire/range
Frigidaire GLGF376DSH Frigidaire/range
Frigidaire GLGF376DSJ GAS RANGE
Frigidaire GLGF376DSK GAS RANGE
Frigidaire GLGF376DSM GAS RANGE
Frigidaire GLGF376DSN GAS RANGE
Frigidaire GLGF376DSR GAS RANGE
Frigidaire GLGF377ABA Frigidaire/gas Range
Frigidaire GLGF377ABC Frigidaire/range
Frigidaire GLGF377ABD Frigidaire/gas Range
Frigidaire GLGF377ABE Frigidaire/gas Range
Frigidaire GLGF377ABF Frigidaire/gas Range
Frigidaire GLGF377ABG Frigidaire/gas Range
Frigidaire GLGF377AQA Frigidaire/gas Range
Frigidaire GLGF377AQC Frigidaire/range
Frigidaire GLGF377AQD Frigidaire/gas Range
Frigidaire GLGF377AQE Frigidaire/gas Range
Frigidaire GLGF377AQF Frigidaire/gas Range
Frigidaire GLGF377AQG Frigidaire/gas Range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana top load belt broke, new belt smokes mikeyfz Washer Repair 1 08-28-2010 05:46 PM
how to remove front to replace belt around drum drphilspeer Dryer Repair 2 08-13-2009 06:15 PM
Where do I find the motor and belt? UberZerstorer Dryer Repair 1 03-08-2009 06:14 PM
how do I remove the metal cabnet and repace a new drum belt Tinas7 Dryer Repair 2 01-03-2008 05:04 PM
Belt off motor dbilloni Dryer Repair 1 09-30-2007 02:20 PM
