Discuss
Maytag Neptune Washer reverses hot-cold water
 in
Washer Repair
Hot and cold water are correctly connected to the machine. When running cold cycle, hot water fills the tub; when
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Neptune Washer reverses hot-cold water
  #1 (permalink)
Old 10-19-2010, 04:09 PM
Junior Member
JohnMe is on a distinguished road
Default Maytag Neptune Washer reverses hot-cold water
Model Number: MAH5500BWW   Brand: Maytag   Age: 5 - 10 years
Hot and cold water are correctly connected to the machine. When running cold cycle, hot water fills the tub; when running hot water, cold water fills. So I reverse the hot/cold hose connections on the back of the machine and everything works fine for the next 5 or 10 loads. Then cold cycle is hot, and hot cylce is cold. So I reverse the hoses on the back again and everything is OK for the next 5 or 10 loads. This keeps happening again and again ... each time I reverse the hoses on the back it works ok for awhile. Is this likely a problem with the main valve where the hoses attach, or a board problem, or something else?
Thanks in advance for any help!
Ads By Google
Related Models
Maytag MAH5500BWW Washer - Horizontal Axis
Maytag MAH55FLBWQ Washer - Horizontal Axis
Maytag MAH55FLBWW Washer - Horizontal Axis
Maytag MAH6500AWQ Washer - Horizontal Axis
Maytag MAH6500AWW Washer - Horizontal Axis
Maytag MAH6700AWM Washer - Horizontal Axis
Maytag MAH6700AWW Washer - Horizontal Axis
Maytag MAH7500AWQ Washer - Horizontal Axis
Maytag MAH7500AWW Washer - Horizontal Axis
International MAH7550AAW Washer - Horizontal Axis
Maytag MAH7550AGW Washer - Horizontal Axis
International MAH7550AGW Washer - Horizontal Axis
Maytag MAH8700AWM Washer - Horizontal Axis
Maytag MAH8700AWW Washer - Horizontal Axis
Maytag MAH9700AWM Washer - Horizontal Axis
Maytag MAH9700AWQ Washer - Horizontal Axis
Maytag MAH9700AWW Washer - Horizontal Axis
Frigidaire MAL123P1A1 Wwh(v1) / Room Air Conditioner
Maytag MAL1800AXM Misc / Accessory
Maytag MAL1800AXQ Misc / Accessory
Maytag MAL1800AXW Misc / Accessory
Maytag MAL2000AXQ Misc / Accessory
Maytag MAL2000AXW Misc / Accessory
Frigidaire MAS183P2A1 Wwh(v1) / Room Air Conditioner
Maytag MAT10CSAAL Washer - Top Loading
Maytag MAT10CSAAW Washer - Top Loading
Maytag MAT10CSAGL Washer - Top Loading
Maytag MAT10CSAGW Washer - Top Loading
Maytag MAT10CSBKL Washer - Top Loading
Maytag MAT10CSEGL Washer - Top Loading
Maytag MAT10CSEGW Washer - Top Loading
Maytag MAT10DAAAL Washer - Top Loading
Maytag MAT10DAAAW Washer - Top Loading
Maytag MAT10DAABL Washer - Top Loading
Maytag MAT10DAABW Washer - Top Loading
Maytag MAT10PDAAL Washer - Top Loading
Maytag MAT10PDAAW Washer - Top Loading
Maytag MAT10PDABL Washer - Top Loading
Maytag MAT10PDABW Washer - Top Loading
Maytag MAT10PDEGW Washer - Top Loading
Maytag MAT10PSAAL Washer - Top Loading
Maytag MAT10PSAAW Washer - Top Loading
Maytag MAT10PSAGL Washer - Top Loading
Maytag MAT10PSAGW Washer - Top Loading
Maytag MAT11CSBKL Washer - Top Loading
Maytag MAT11MNAAW Washer - Top Loading
Maytag MAT11MNAGW Washer - Top Loading
Maytag MAT11MNEGW Washer - Top Loading
Maytag MAT11PDAAL Washer - Top Loading
Maytag MAT11PDAAW Washer - Top Loading
Maytag MAT11PDABL Washer - Top Loading
Maytag MAT11PDABW Washer - Top Loading
Maytag MAT12CSAAL Washer - Top Loading
Maytag MAT12CSAAQ Washer - Top Loading
Maytag MAT12CSAAW Washer - Top Loading
Maytag MAT12CSAGW Washer - Top Loading
Maytag MAT12CSAKL Washer - Top Loading
Maytag MAT12CSAKQ Washer - Top Loading
Maytag MAT12CSDAQ Washer - Top Loading
Maytag MAT12CSDAW Washer - Top Loading
Maytag MAT12CSDGW Washer - Top Loading
Maytag MAT12CSEGW Washer - Top Loading
Maytag MAT12CSFWQ Washer - Top Loading
Maytag MAT12CSFWW Washer - Top Loading
Maytag MAT12PDAAL Washer - Top Loading
Maytag MAT12PDAAW Washer - Top Loading
Maytag MAT12PDABL Washer - Top Loading
Maytag MAT12PDABW Washer - Top Loading
Maytag MAT12PDAGW Washer - Top Loading
Maytag MAT12PDBAL Washer - Top Loading
Maytag MAT12PDBAQ Washer - Top Loading
Maytag MAT12PDBAW Washer - Top Loading
Maytag MAT12PDBBL Washer - Top Loading
Maytag MAT12PDBBQ Washer - Top Loading
Maytag MAT12PDBBW Washer - Top Loading
Maytag MAT12PDCBL Washer - Top Loading
Maytag MAT12PDCBQ Washer - Top Loading
Maytag MAT12PDCBW Washer - Top Loading
Maytag MAT12PDDAQ Washer - Top Loading
Maytag MAT12PDDAW Washer - Top Loading
Maytag MAT12PDDBW Washer - Top Loading
Maytag MAT12PDDGW Washer - Top Loading
Maytag MAT12PDEGW Washer - Top Loading
Maytag MAT12PDLAQ Washer - Top Loading
Maytag MAT12PDLAW Washer - Top Loading
Maytag MAT12PDLGW Washer - Top Loading
Maytag MAT12PDSAW Washer - Top Loading
Maytag MAT12PRAAW Washer - Top Loading
Maytag MAT12PRAEW Washer - Top Loading
Maytag MAT12PRBAW Washer - Top Loading
Maytag MAT12PRDAW Washer - Top Loading
Maytag MAT12PRSAW Washer - Top Loading
Maytag MAT12PSAAW Washer - Top Loading
Maytag MAT12PSAGW Washer - Top Loading
Maytag MAT12PSBAW Washer - Top Loading
Maytag MAT12PSDAW Washer - Top Loading
Maytag MAT12PSLWQ Washer - Top Loading
Maytag MAT12PSLWW Washer - Top Loading
Maytag MAT13MNAAW Washer - Top Loading
Maytag MAT13MNAGW Washer - Top Loading
Maytag MAT13MNDAW Washer - Top Loading
Maytag MAT13MNDGW Washer - Top Loading
Maytag MAT13MNEGW Washer - Top Loading
Maytag MAT13PDAAW Washer - Top Loading
Maytag MAT13PDBAW Washer - Top Loading
Maytag MAT13PNAEW Washer - Top Loading
Maytag MAT13PNDEW Washer - Top Loading
Maytag MAT13PRBWW Washer - Top Loading
Maytag MAT230CAAG Washer - Top Loading
Maytag MAT23PCAAC Washer - Top Loading
Maytag MAT23PCAAG Washer - Top Loading
Maytag MAT23PCAAL Washer - Top Loading
Maytag MAT23PCAAW Washer - Top Loading
Maytag MAT23PCABG Washer - Top Loading
Maytag MAT23PCABL Washer - Top Loading
Maytag MAT23PCABW Washer - Top Loading
Maytag MAT25CSAAG Washer - Top Loading
Maytag MAT25CSAAL Washer - Top Loading
Maytag MAT25CSAAW Washer - Top Loading
Maytag MAT25CSAGG Washer - Top Loading
  #2 (permalink)
Old 10-19-2010, 06:11 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Cannot say I have experienced your problem, but I think the issue is with the control board and not with the valve assembly.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag washer will not agitate/cold water fill won't shut off denise2855 Washer Repair 12 03-09-2012 06:44 PM
Maytag Neptune Washer no hot water harperhomewa Washer Repair 2 03-29-2011 01:29 PM
Maytag washer no cold water during cycle, but finger faucet works jimbojamble Washer Repair 0 09-25-2010 10:23 AM
Maytag front load washer will not fill with cold water gclosius Washer Repair 1 11-29-2009 12:27 PM
maytag washer neptune only put out warm or hot water no cold misterfixall Washer Repair 0 11-22-2007 03:16 PM
