Discuss
Washer will not spin
 in
Washer Repair
I am not sure about the age of the washer. I changed the agitators about 4 months ago and everything
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer will not spin
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 09-29-2007, 09:11 AM
Darren Darren is offline
Junior Member
Darren is on a distinguished road
Default Washer will not spin
Model Number: GST9344EQO   Brand: Maytag   Age: 5 - 10 years
I am not sure about the age of the washer. I changed the agitators about 4 months ago and everything has been fine. Today we heard a different noise and it was the motor running but it is not spinning.
From what I can tell look at the breakout it could be a clutch?
What do you think and what ever you suggest is it hard to replace?
Darren
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-24-2007, 09:11 PM
jdappl07 jdappl07 is offline
Senior Expert
APP Volunteer
jdappl07 is on a distinguished road
Default
if the machine will not aggitate if is the motor coupling if it does then its a clutch also see if something is in the pump
  #3 (permalink)
Old 10-25-2007, 09:57 AM
angcal angcal is offline
Junior Member
angcal is on a distinguished road
Default GE Washer loud noise
My GE Washer model # (wpsf4170w0aa) my ge washer mackes loud moises when spinning and if the load is slightly heavy it will not spin can you help
  #4 (permalink)
Old 10-26-2007, 02:26 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
You have a Whirlpool washer! If it will not agitate also=bad coupler.
If failed in spin, you may have something caught in the tub or dragging brake shoes. Shine a light in basket and check for stuff, if ok, replace the coupler and turn tranny coupler clockwise till the basket starts to spin. If hard to turn with one hand, you have dragging brake shoes. Post results.
__________________
  #5 (permalink)
Old 10-26-2007, 01:41 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi angcal
The first thing I would check is the belt. Replace it if it's worn out.
If there is nothing wrong with the belt then most likely the problem is a bad transmission.
- Here are the break down diagrams for the GE washer Model WPSF4170W0AA
Good luck.
__________________
Professional appliance repair services in Orange County, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer will not spin chevy2 Washer Repair 6 03-10-2008 12:47 PM
washer noisy during spin djgabor Washer Repair 0 09-22-2007 12:03 PM
Washer won't spin arnoldte Washer Repair 1 09-19-2007 09:04 PM
Washer does not spin Bill Noonan Washer Repair 0 09-12-2007 05:46 AM
my washer won't spin jopas213 Washer Repair 5 08-21-2007 02:02 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
