| » Front load Whirlpool Washer will not start |
Model Number: GHW9200LW Brand: Whirlpool Age: 5 - 10 years
When I select a program, then press and hold the 'Start' button, nothing happens. The machine is powered. The 'On' button does turn the appropriate lights on. All buttons as well as the dial for selecting wash programs work perfectly.
Normally, when I press and hold the 'Start' button after selecting a wash program, there is a clicking sound that is followed by the sound of water flowing into the machine. This time, nothing happens when I press and hold the 'Start' button. Any ideas? Ads By Google Related Models |
Quote:
Did you open then close the door and try again ? The door must be opened and closed between cycles. The next thing to check from there, is the door lock door switch assembly and wiring. You may want to remove the top panel(two screws on the back of the unit, and slide back top) to access the technical data sheet, so you can run the diagnostics and test mode. Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| GE Front Load Washer won't start - model WBVH6240FWW | mejmea | Washer Repair | 14 | 10-25-2010 06:15 PM |
| Front load whirlpool washer | JDPjr | Washer Repair | 2 | 08-03-2010 06:25 AM |
| My front load washer will not start. push start and nothing happens | kimmoe | Washer Repair | 1 | 01-06-2010 01:41 PM |
| coin washer front load wont start | searsnumberone | Washer Repair | 0 | 09-22-2009 03:04 PM |
