sailman
#1 Posted : Monday, October 20, 2008 5:02:28 AM(UTC)
sailman
On Perm Press and Delicate My washer skips second wash/agitate cycle. After first fill/agitate/ drain/spin,the washer refills does not agitate but timer continues normally to final drain/spin. Normal cycle same except does not proceed to the final drain/spin. I have to manually move the dial to another spin cyce. I believe this model has a two-speed motor. Can one speed go bad ? Is it a timer issue ?
magician59
#2 Posted : Monday, October 20, 2008 5:31:15 AM(UTC)
magician59
Sounds like a bad timer.
sailman
#3 Posted : Monday, October 20, 2008 5:50:18 AM(UTC)
sailman
cabinet is off. Any chance one of the two-speed motor winidings is bad ? How can I test the motor to eliminate this possibility ?
magician59
#4 Posted : Monday, October 20, 2008 6:21:20 AM(UTC)
magician59
If the machine spins and agitates, even in different cycles, the motor is good. It sounds by your description of the problem like you have a bad timer.
