| » Maytag washer Error Code F51 |
Model Number: MTW6600TB0 Brand: Maytag Age: 1 - 5 years
I am getting a Error code of F51 on my Maytag Bravos. Can you tell me what is the problem this indicates.
Thanks Scott Ads By Google Related Models |
Quote:
Scott, The F 51 code, would indicate, the control board is not seeing the proper resistance on the motor circuit . You should check and make sure there are not any articles, stuck between the tubs, or under the agitator. Make sure you're not overloading the machine.and you have proper voltage to the unit. Have you run the unit through a cycle empty ? You may want to try that, before we have to get too involved in circuit and voltage tests. Your technical data sheet should be on the inside of the front panel, you'll need to raise the top of the washer, using a putty knife to release the clips in the front seam, holding the top down .
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
I got the same problem. Started with a F50 so I disassembled the entire washer to see what was wrong. I checked the voltage on the connector to the motor and it read good resistance per the tech guide.
I ran the motor test without the basket and the shaft appears to jerk every now and again. At high speeds, the shaft stalls and then starts again. I already replaced the RPS with no change. My thought now is that it is the tub and the bearing on the shaft to the motor. Anyone might agree with me? The motor and the motor cover looks good and measures good with the meter. Maytag Bravos Washer - MTW6700TQ1 |
Quote:
Rularn, Did you install the complete kit ? Part number: AP4327312 Did you make sure all the connections were tight and proper, especially at the CCU and RPS ? At this point, I would hate to see you replace an outer tub and shaft,on a maybe. Usually, they will make some sort of noise when they begin to fail, and the majority of the agitate/spin problems, are due to a bad RPS or loose wire connection. Did you have any other failure codes ? or symptoms ?
__________________
Thanks for the reply. The only codes I get are F50 and F51: motor and RPS. I checked the wire harness from the machine control to the RPS and motor and it's all good too.
In manual test, after the shaft will start at high speeds, it will stall. Sometimes the shaft will jerk before it starts spinning at low speeds. Sometimes I have to hand spin it a little once before the drive shaft starts to spin at low speeds at the start of the manual test. |
Quote:
Rularn, It still sounds like it's a circuit problem, Something you may want to try, (if the tub is still out). Put 2 or 3 drops of 3in1 oil between the shaft and the tub bearing,and give it a few seconds to drip down the shaft, then try the spin, again, I think you'll find you still have the same results, then we can move on from there Good Luck,
__________________
| Display Modes | |
| Maytag neptune error code | brockner75 | Washer Repair | 2 | 02-12-2012 04:20 PM |
| Please Help F3 error code on Maytag oven | barnz2000 | Oven Repair (including Ranges and Cooktops) | 0 | 03-19-2010 04:49 PM |
| Maytag Neptune error code: L5 or E5 | skalesplitur | Washer Repair | 1 | 03-05-2010 06:46 AM |
| Maytag refrig error code | Markie21 | Refrigerator & Freezer Repair | 1 | 04-02-2009 06:37 PM |
| Maytag Gemini Error Code F1-4 | Bondy | Oven Repair (including Ranges and Cooktops) | 1 | 10-27-2008 09:36 AM |
