Discuss
Maytag washer Error Code F51
 in
Washer Repair
Originally Posted by Joe / APP Team Kampkand, That's a very likely possibility. You've checked or repaired everything else. it's
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag washer Error Code F51
  #51 (permalink)
Old 03-07-2017, 04:14 PM
Junior Member
Kampkand is on a distinguished road
Default
Quote:
Originally Posted by Joe / APP Team View Post
Kampkand, That's a very likely possibility. You've checked or repaired everything else. it's a "sensitive" part and doesn't take much for it to malfunction. You would want to consider the Part number: AP4327312
that way you get a new wire harness, sensor and cover. Make sure you install all the parts. That way you have checked cleaned and repaired the drive system, and it should be quite awhile before you need anything else.
Ok thanks Joe, I have ordered that kit and will let you know what happens.
  #52 (permalink)
Old 03-08-2017, 06:03 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Kampkand,
OK, Good deal Thanks,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #53 (permalink)
Old 03-15-2017, 08:51 PM
Junior Member
Default
Kampkand,
Hey Joe, sorry I have been away for the last few days. I have installed the new parts and I can wash again, however it is limited to very small quantities of clothes. If I put too much in I get the F51 error code again. I'm thinking now that it's probably the rotor that is giving me grief now.
At this point I think I'm going to buy a new one, as the rotor is another $230.
Thanks again for all your help
  #54 (permalink)
Old 03-16-2017, 06:31 AM
Senior Expert
Default
Kampkand, Sometimes that can happen, fortunately not very often. Was pretty sure after all the checks and rechecks you made the washer would be up and running. Sorry it didn't work out. Good Luck !!!
__________________
Joe M. APP TEAM
  #55 (permalink)
Old 05-21-2017, 06:08 PM
Junior Member
Kylew is on a distinguished road
Smile F51 error code maytag bravos
After taking agitator and tub out there was a small rag in the bottom of the washer. Cleaned all equipment and put back together. Still had the same error at either 26 minutes or 15 minutes. Troubleshooted for a while, putting machine into manual and going through each cycle, intermittently would kick out at the agitation cycle. Ended up watching a video on changing the rps sensor on the bottom of the machine and whilst taking apart, the first two bolts I took off were completely loose. Giving it a shot, I went no further, tightened the bolts and haven't had an issue since. Works like new and didn't have to buy any parts. Thinking those loose bolts may have been setting the sensor off thinking it was uneven load. All good now. Back to washing blankets and comforters.
  #56 (permalink)
Old 05-22-2017, 06:26 AM
Senior Expert
Default
Quote:
Kylew, GREAT !!! We're glad to know you're machine is up and running. We had a feeling you would find the problem and have it repaired in no time. Your update information should be helpful to those that read the repair forum when trying to repair their "Cabrio" style washer. Thanks Again,
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag neptune error code brockner75 Washer Repair 2 02-12-2012 04:20 PM
Please Help F3 error code on Maytag oven barnz2000 Oven Repair (including Ranges and Cooktops) 0 03-19-2010 04:49 PM
Maytag Neptune error code: L5 or E5 skalesplitur Washer Repair 1 03-05-2010 06:46 AM
Maytag refrig error code Markie21 Refrigerator & Freezer Repair 1 04-02-2009 06:37 PM
Maytag Gemini Error Code F1-4 Bondy Oven Repair (including Ranges and Cooktops) 1 10-27-2008 09:36 AM
