Discuss
Maytag washer Error Code F51
 in
Washer Repair
Not sure that I am 100% sure exactly where this is,"water inside the rotor/stator assembly ?" I can say that
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag washer Error Code F51
  #11 (permalink)
Old 03-24-2014, 03:15 PM
Junior Member
klcannon67 is on a distinguished road
Default
Not sure that I am 100% sure exactly where this is,"water inside the rotor/stator assembly ?" I can say that when I put the rotor motor/cover back on, there is still water in the outer drum where it was suppose to have already drained. This unit is approx 5 years old and not used like my old washer when the boys were younger and home. In fact it sat in storage 6 plus months just over 3 years ago.I have not been overly impressed with it, but got a great deal and they are Maytag, thought I wouldn't have issues. I have had code issues ll along...... Overall it has been pretty gently used. Sorry for going on, SO, as far as moisture or water, am I looking in the right place or are you asking if there was any around/in the parts I had pulled. It has started to give me the UL code as well.
  #12 (permalink)
Old 03-25-2014, 06:57 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Kl, When you replaced the RPS kit
Part number: AP4327312
You needed to remove the rotor
Part number: AP3882831
and the stator
Part number: AP5306946
When you removed these parts, did you notice water, debris, or discoloration on the inside of the rotor. If so, this could indicate an issue with the tub seal, that would eventually wash out the lubricant in the tub bearing and shaft assembly. In time the bearing would start to seize up and create a noise, the F51 code as well as the UL(unbalanced load) code. If the tub cant reach the proper speed within the time allotted, it will create a code.
There is always a small amount of water left in the outer tub after a cycle, a half cup or so, if there's more than that, then you need to check the hoses and drain pump for obstructions or kinks twists etc. you may have to remove the tub cover and tub to check and make sure there's nothing small stuck between the tubs.
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #13 (permalink)
Old 03-25-2014, 03:48 PM
Junior Member
Default
No water there. I did get a lot of grease on my hands from the Part number: AP4327312, the metal ring. Should I put any back,(if so, what type?), because since this replacement, it has the noise and now not only did I get the UL code in the spin cycle, it won't complete a spin. It will do the alert like the cycle is finished and it isn't. Clothes are still pretty wet. I appreciate your assistance. I can't really afford to pay a repairman since I have been out of work awhile, so thought I would do the DYI method. It wasn't hard but now it seems I have created another issue. Also, I have already checked between the tubs, I don't find any item(s) that may have gone over the side of the inner tub. Again, I appreciate your assistance.
  #14 (permalink)
Old 03-26-2014, 07:00 AM
Senior Expert
Default
Klcannon, Just a small dab of grease on the surface of the end of the impeller shaft, is all that's needed. the end of the shaft that seats in the rotor. When you installed the [AP4327312] sensor kit, did you use all the parts ? If not you'll need to install the remaining parts.
Get the tech data sheet from the inside of the washer front panel, and review the error codes, so we can get an idea of what the control board is seeing and registering in the eeprom memory, since the repair.
Chances are, you'll need to remove the rotor and stator, and recheck everything and make sure all the bolts are tightened evenly and correctly.
__________________
Joe M. APP TEAM
  #15 (permalink)
Old 03-26-2014, 08:05 AM
Junior Member
Default
All parts were replaced, that is a definite. Will follow up on the rest of the info. Thanks so much!
  #16 (permalink)
Old 03-26-2014, 08:31 AM
Senior Expert
Default
OK, Keep in touch, we'll get this washer going one way or another.
__________________
Joe M. APP TEAM
  #17 (permalink)
Old 03-29-2014, 04:25 PM
Junior Member
Default
Grease helped. Still have a bit of a scratching/rubbing noise but it sounds like it is coming from either the agitator or the baskets, don't know. Any advice on that? I have checked all screws, etc. She is running and so far so good, hopefully I won't return with this issue......Thanks for all of your help!
  #18 (permalink)
Old 03-31-2014, 08:07 AM
Senior Expert
Default
Kl, It's not likely the tub or basket. But you do want to recheck the hub assembly
Part number: AP3892170
If the "teeth" on either of the hubs are distorted or "rounded off" or worn to the point that they can't engage together, there will be a noise from the center of the tubs.
__________________
Joe M. APP TEAM
  #19 (permalink)
Old 04-03-2014, 03:48 AM
Junior Member
Default
Would this continue to give me an F51 code? I still get that after 2 plus loads and have replaced the sensor. The noise was minimal after rechecking things and adding some grease but increased again before it went out again. Thanks!
  #20 (permalink)
Old 04-07-2014, 07:18 AM
Senior Expert
Default
Yes, it could be the cause of the F 51 code and the noise. If the tub hub doesn't engage the shaft hub properly, this can cause a "drag" on the drive system and create the F 51 error code. You also want to check and make sure, that once the tub is full of water the spin basket has floated up at least 3/8 of an inch, This will give the proper clearance between the tubs, and the agitator until the washer drains and the tub resets on the shaft properly.
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag neptune error code brockner75 Washer Repair 2 02-12-2012 04:20 PM
Please Help F3 error code on Maytag oven barnz2000 Oven Repair (including Ranges and Cooktops) 0 03-19-2010 04:49 PM
Maytag Neptune error code: L5 or E5 skalesplitur Washer Repair 1 03-05-2010 06:46 AM
Maytag refrig error code Markie21 Refrigerator & Freezer Repair 1 04-02-2009 06:37 PM
Maytag Gemini Error Code F1-4 Bondy Oven Repair (including Ranges and Cooktops) 1 10-27-2008 09:36 AM
