When The Tub Fills With Water The Machine Will Not Go Into The Wash Mode. What Is Most Likely The Problem?
Does this happen in all the available cycles?
Originally Posted by: magician59 Does this happen in all the available cycles? yes. When I turn the timer knob to try a different cycle, nothing happens. My thought is that the timer is defective but the part is so expensive that I do not want to order it unless I'm fairly certain that I'm correct
Originally Posted by: magician59 You're correct. I believe it is the lid switch. I shorted out the switch and it began operating. Thanks
