Discuss
Loud spin cycle on Elite Oasis washer
 in
Washer Repair
Our washer works fine but during spin cycle, it's really loud - so loud we can hear it from upstairs.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Loud spin cycle on Elite Oasis washer
  #1 (permalink)
Old 10-11-2010, 08:36 AM
Junior Member
raf215 is on a distinguished road
Default Loud spin cycle on Elite Oasis washer
Model Number: 110.27082603   Brand: Kenmore   Age: 1 - 5 years
Our washer works fine but during spin cycle, it's really loud - so loud we can hear it from upstairs. No grinding, no oil on inside, just loud. I've read where it can be the clutch assembly. Could it be the bearing? Thanks
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 10-11-2010, 09:41 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
RAF,
Have you noticed any leaks from the machine, or water on the floor ?
Your unit is a "Direct Drive" unit and has no clutch.
You are most likely correct in assuming it may be a bad bearing.
But that can be proceeded by a water leak,(not always, but usually).
It would require a complete outer tub assembly, Once you've removed the spin basket and checked for possible articles between the tubs, and loose or damaged motor shaft seal.
Part number: AP4316595
Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 02-21-2011, 07:53 AM
Junior Member
porktyme is on a distinguished road
Default Kenmore Oasis loud noise during spin
Wow what a great site. I have a Kenmore Oasis 110.27032600 from 2007. The washer makes a loud humming noise during spin. Took it apart for bad bearing. The bearings have leaked grease.
What is the part number that includes the shaft and bearings? I'd like to buy just the basket but's its unclear whether that includes the shaft.
Thanks for any help.
  #4 (permalink)
Old 02-21-2011, 09:15 AM
Senior Expert
Default
Porktyme,
I take for granted,
Your washer does wash, and you've found that your washer doesn't spin, and the motor hums because the bearing shaft is dragging or seized up due to the leak.
You're on track, though.
Should you order the outer tub assembly,
You'll recieve all the parts you'll need( drive shaft, bearings, and seal) to take care of the leak and grease.
I only hope theres no damage to the motor stator and sensor assembly.
Good Luck,
__________________
Joe M. APP TEAM
  #5 (permalink)
Old 02-21-2011, 09:42 AM
Junior Member
Default
Update to my original post.
I called Sears and for the cost of the repair tech, both the inner and outer tubs were replaced as I found out that those 2 pieces have a 10 year warranty. Took tech about 45 minutes to repair and washer is good as new!
  #6 (permalink)
Old 02-21-2011, 11:20 AM
Senior Expert
Default
RAF,
Thanks for the update.
We're glad things are up and running, and you're happy.
Good Luck,
__________________
Joe M. APP TEAM
  #7 (permalink)
Old 02-21-2011, 01:03 PM
Junior Member
Default
Joe, that's great. Except the part# you provided is out of stock. Any other suggestions?
Part Details - WHIRLPOOL TUB-OUTER, part number: AP4316595
  #8 (permalink)
Old 02-21-2011, 02:59 PM
Senior Expert
Default
Porktyme,
I do show that part available in one of our warehouses(several to be more exact).
Our parts order screens are not "same time" and we occasionally have mis information.
I'm sure if you order it, you'll recieve it, in a timely manner.
__________________
Joe M. APP TEAM
  #9 (permalink)
Old 02-22-2011, 06:44 AM
Junior Member
Default
Order placed. Thanks for all your help!
  #10 (permalink)
Old 02-22-2011, 07:15 AM
Senior Expert
Default
My pleasure,
Drop us a line if you need more assistance, or when you're through with the repair.
We're here to help,
Good Luck,
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Elite Oasis Top Loader will not drain or spin Rolo1 Washer Repair 20 09-03-2013 12:04 PM
Kenmore Elite Oasis Washer making grinding sounds during spin cycle ev372 Washer Repair 1 05-27-2010 08:38 PM
washer loud spin cycle rottweiler Washer Repair 4 01-10-2010 09:09 AM
help with kenmore elite oasis washer tdavid64 Washer Repair 9 01-01-2010 03:05 PM
Kenmore Elite Oasis HE Washer bap2523 Washer Repair 0 09-09-2009 06:07 AM
