Discuss
Drain Pump in Odd Place
 in
Washer Repair
Hi. This model clothes washer will not drain the water after the cleaning cycle. I can drain it manually into
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Drain Pump in Odd Place
  #1 (permalink)
Old 10-10-2010, 03:14 PM
Junior Member
UserNameHere is on a distinguished road
Default Drain Pump in Odd Place
Model Number: LA5300XMNO   Brand: Whirlpool   Age: More than 10 years
Hi. This model clothes washer will not drain the water after the cleaning cycle. I can drain it manually into a bucket and then the spin cycle works. From your site and a few others I have perused, the diagnosis seems to be a bad drain pump. It is either jammed or history. However the pump is not right in the back by the one 14" x 14" opening nor does the top come off like any of the other models. I have had to unhook every single wire harness ect and to make a long story short, the pump is on the left side of the washer with absolutely no way to access the thing unless, it appears, that I sit it on its' side and even then I won't have a clear view of it. Do I have to take this apart piece by piece to get to that pump? There is no access panel on the left side. There was a rubberry smell when the washer wouldn't drain. There are no water or oil leaks. The lid switch clicks just fine also. I'm pretty sure it is the pump because the belt looks almost brand new amazingly. How the heck do I get to that pump? Do I need to keep going? Sheesh I'll have the whole thing disassembled. Oh and there is no place to hold the panel up either and I had to completely remove that which included a wiring harness, a vacuum tube and a ground wire. Is there something I am unaware of? I'm a carpenter and "put a nail in it" just won't work! I hope my problem is clear and I really appreciate your time. Thanks!
Ads By Google
Related Models
Whirlpool LA5300XMW0
Whirlpool LA5300XMW1
Whirlpool LA5300XPW0
Whirlpool LA5300XPW1
Whirlpool LA5300XPW2
Whirlpool LA5300XPW3
Whirlpool LA5300XPW4
Whirlpool LA5300XPW5
Whirlpool LA5300XSF1 AUTOMATIC WASHERS
Whirlpool LA5300XSF2 AUTOMATIC WASHER
Whirlpool LA5300XSG1 AUTOMATIC WASHERS
Whirlpool LA5300XSG2 AUTOMATIC WASHER
Whirlpool LA5300XSM1 AUTOMATIC WASHERS
Whirlpool LA5300XSM2 AUTOMATIC WASHER
Whirlpool LA5300XSN0 AUTOMATIC WASHER
Whirlpool LA5300XSN1 AUTOMATIC WASHERS
Whirlpool LA5300XSN2 AUTOMATIC WASHER
Whirlpool LA5300XSW0
Whirlpool LA5300XSW1
Whirlpool LA5300XSW2
Whirlpool LA5300XTF0 AUTOMATIC WASHER
Whirlpool LA5300XTF1 AUTOMATIC WASHER
Whirlpool LA5300XTG0 AUTOMATIC WASHER
Whirlpool LA5300XTG1 AUTOMATIC WASHER
Whirlpool LA5300XTM0 AUTOMATIC WASHER
Whirlpool LA5300XTM1 AUTOMATIC WASHER
Whirlpool LA5300XTN0 AUTOMATIC WASHER
Whirlpool LA5300XTN1 AUTOMATIC WASHER
Whirlpool LA5300XTW0
Whirlpool LA5300XTW1
Whirlpool LA5310XPW0
Whirlpool LA5310XSW0
Whirlpool LA5311XPW3
Whirlpool LA5311XPW4
Whirlpool LA5311XPW5
Whirlpool LA5320XTF0
Whirlpool LA5320XTG0
Whirlpool LA5320XTM0
Whirlpool LA5320XTN0
Whirlpool LA5320XTW0
Whirlpool LA5330XSW0
Whirlpool LA5330XSW1
Whirlpool LA5330XTF0
Whirlpool LA5330XTG0
Whirlpool LA5330XTM0
Whirlpool LA5330XTN0
Whirlpool LA5330XTW0
Whirlpool LA5360XSW0
Whirlpool LA5360XSW1
Whirlpool LA5360XTF0
Whirlpool LA5360XTG0
Whirlpool LA5360XTM0
Whirlpool LA5360XTN0
Whirlpool LA5360XTW0
Whirlpool LA5380XMW0
Whirlpool LA5380XPW0
Whirlpool LA5380XPW1
Whirlpool LA5380XPW2
Whirlpool LA5380XSW0
Whirlpool LA5380XSW1
Whirlpool LA5380XTF0
Whirlpool LA5380XTF1
Whirlpool LA5380XTG0
Whirlpool LA5380XTG1
Whirlpool LA5380XTM0
Whirlpool LA5380XTM1
Whirlpool LA5380XTN0
Whirlpool LA5380XTN1
Whirlpool LA5380XTW0
Whirlpool LA5380XTW1
Whirlpool LA5381XXF0
Whirlpool LA5381XXF1
Whirlpool LA5381XXG0
Whirlpool LA5381XXG1
Whirlpool LA5381XXM0
Whirlpool LA5381XXM1
Whirlpool LA5381XXN0
Whirlpool LA5381XXN1
Whirlpool LA5381XXW0
Whirlpool LA5381XXW1
Whirlpool LA5400XMW0
Whirlpool LA5400XMW1
Whirlpool LA5400XMW2
Whirlpool LA5400XMW3
Whirlpool LA5400XPW0
Whirlpool LA5400XPW1
Whirlpool LA5400XPW3
Whirlpool LA5400XPW5
Whirlpool LA5400XSW0
Whirlpool LA5400XSW1
Whirlpool LA5400XTF0
Whirlpool LA5400XTF1
Whirlpool LA5400XTG0
Whirlpool LA5400XTG1
Whirlpool LA5400XTM0
Whirlpool LA5400XTM1
Whirlpool LA5400XTN0
Whirlpool LA5400XTN1
Whirlpool LA5400XTW0
Whirlpool LA5400XTW1
Whirlpool LA5420XTF0
Whirlpool LA5420XTG0
Whirlpool LA5420XTM0
Whirlpool LA5420XTN0
Whirlpool LA5420XTW0
Whirlpool LA5430XMW0
Whirlpool LA5430XMW1
Whirlpool LA5430XMW2
Whirlpool LA5430XMW3
Whirlpool LA5430XPW0
Whirlpool LA5430XPW1
Whirlpool LA5430XPW3
Whirlpool LA5430XPW5
Whirlpool LA5430XSW0
Whirlpool LA5430XSW1
Whirlpool LA5430XTF0
Whirlpool LA5430XTF1
Whirlpool LA5430XTG0
Whirlpool LA5430XTG1
Whirlpool LA5430XTM0
  #2 (permalink)
Old 10-11-2010, 02:38 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
You need to lay the washer on it's face, remove the back panel, remove the belt, and check the pump, probably stuck.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dishwasher will not drain (drain pump is new) jkda1975 Dishwasher Repair 1 04-06-2010 01:56 PM
bosch shu9925 - drain pump works, won't drain after cycle mjbarr Dishwasher Repair 0 10-16-2009 01:11 PM
Getting to the drain pump mommylam Dishwasher Repair 1 10-30-2008 03:55 PM
will this pump also pump the drain water out Paul Radovsky Dishwasher Repair 5 07-20-2008 01:41 PM
Drain Pump loadster Dishwasher Repair 1 08-07-2007 06:35 PM
