Discuss
Smoking belts on spin cycle
 in
Washer Repair
Wodering if antone knows of a common problem with this machine? I changed the belts and ran it thru a
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Smoking belts on spin cycle
  #1 (permalink)
Old 10-10-2010, 12:05 PM
Junior Member
Kevco is on a distinguished road
Default Smoking belts on spin cycle
Model Number: LAT9206BAE   Brand: Maytag   Age: 5 - 10 years
Wodering if antone knows of a common problem with this machine? I changed the belts and ran it thru a complete cycle it did fine until it got to the spin cycle. Then it locked up and the belts started to smoke bad. Wonderin if the tranny may be toast? Or if someone has ran into this before. In this economy Im trying to fix versus replace. Thanks for your help.
Related Models
Maytag LAT9206BAE WASHER-TOP LOADING
Maytag LAT9206BAM WASHER-TOP LOADING
Maytag LAT9206BAQ WASHER-TOP LOADING
Maytag LAT9206BBE WASHER-TOP LOADING
Maytag LAT9206BBM WASHER-TOP LOADING
Maytag LAT9235AAE WASHER-TOP LOADING
Maytag LAT9235AAM WASHER-TOP LOADING
Maytag LAT9280AAL WASHER-TOP LOADING
Maytag LAT9280AAW WASHER-TOP LOADING
Maytag LAT9280ABL WASHER-TOP LOADING
Maytag LAT9280ABW WASHER-TOP LOADING
Maytag LAT9300AAL WASHER-TOP LOADING
Maytag LAT9300AAW WASHER-TOP LOADING
Maytag LAT9300ABL WASHER-TOP LOADING
Maytag LAT9300ABW WASHER-TOP LOADING
Maytag LAT9304AAE WASHER-TOP LOADING
Maytag LAT9304AAL WASHER-TOP LOADING
Maytag LAT9304AAM WASHER-TOP LOADING
Maytag LAT9304ABE WASHER-TOP LOADING
Admiral LAT9304AGE WASHER-TOP LOADING
Admiral LAT9304AGL WASHER-TOP LOADING
Admiral LAT9304AGM WASHER-TOP LOADING
Admiral LAT9304BGE WASHER-TOP LOADING
Maytag LAT9304DAL WASHER-TOP LOADING
Maytag LAT9304DAM WASHER-TOP LOADING
Admiral LAT9304EGE WASHER-TOP LOADING
Admiral LAT9304GGE WASHER-TOP LOADING
Maytag LAT9306AAE WASHER-TOP LOADING
Maytag LAT9306AAM WASHER-TOP LOADING
Maytag LAT9306ABE WASHER-TOP LOADING
Admiral LAT9306AGE WASHER-TOP LOADING
Admiral LAT9306AKM WASHER-TOP LOADING
Admiral LAT9306AKQ WASHER-TOP LOADING
Admiral LAT9306BGE WASHER-TOP LOADING
Admiral LAT9306DAM WASHER-TOP LOADING
Admiral LAT9306DAQ WASHER-TOP LOADING
Admiral LAT9306EGE WASHER-TOP LOADING
Admiral LAT9306GGE WASHER-TOP LOADING
Maytag LAT9314AAE WASHER-TOP LOADING
Maytag LAT9314AAL WASHER-TOP LOADING
Maytag LAT9314AAM WASHER-TOP LOADING
Maytag LAT9314ABE WASHER-TOP LOADING
Maytag LAT9316AAE WASHER-TOP LOADING
Maytag LAT9316AAM WASHER-TOP LOADING
Maytag LAT9316ABE WASHER-TOP LOADING
Maytag LAT9316ABM WASHER-TOP LOADING
Maytag LAT9334AAE WASHER-TOP LOADING
Maytag LAT9334AAL WASHER-TOP LOADING
Maytag LAT9334AAM WASHER-TOP LOADING
Maytag LAT9334ABE WASHER-TOP LOADING
Maytag LAT9356AAE WASHER-TOP LOADING
Maytag LAT9356AAM WASHER-TOP LOADING
Maytag LAT9356AAQ WASHER-TOP LOADING
Maytag LAT9356ABE WASHER-TOP LOADING
Maytag LAT9356ABM WASHER-TOP LOADING
Maytag LAT9357AAE WASHER-TOP LOADING
Maytag LAT9357AAM WASHER-TOP LOADING
Maytag LAT9357AAQ WASHER-TOP LOADING
Maytag LAT9360AAE WASHER-TOP LOADING
Maytag LAT9390AAE WASHER-TOP LOADING
Maytag LAT9400AAE WASHER-TOP LOADING
Maytag LAT9400AAL WASHER-TOP LOADING
Maytag LAT9400AAW WASHER-TOP LOADING
Maytag LAT9400ABE WASHER-TOP LOADING
Maytag LAT9400ABL WASHER-TOP LOADING
Maytag LAT9400ABW WASHER-TOP LOADING
Maytag LAT9400AGL WASHER-TOP LOADING
Maytag LAT9400AGW WASHER-TOP LOADING
Maytag LAT9400DAL WASHER-TOP LOADING
Maytag LAT9400DAW WASHER-TOP LOADING
Maytag LAT9406AAE WASHER-TOP LOADING
Maytag LAT9406AAM WASHER-TOP LOADING
Maytag LAT9406ABE WASHER-TOP LOADING
Maytag LAT9416AAE WASHER-TOP LOADING
Maytag LAT9416AAM WASHER-TOP LOADING
Maytag LAT9416AAQ WASHER-TOP LOADING
Maytag LAT9420AAE WASHER-TOP LOADING
Maytag LAT9457AAE WASHER-TOP LOADING
Maytag LAT9457AAM WASHER-TOP LOADING
Maytag LAT9457AAQ WASHER-TOP LOADING
Maytag LAT9457BAE WASHER-TOP LOADING
Maytag LAT9520AAE WASHER-TOP LOADING
Maytag LAT9520AAQ WASHER-TOP LOADING
Maytag LAT9557AAE WASHER-TOP LOADING
Maytag LAT9557AAQ WASHER-TOP LOADING
Maytag LAT9593AAL WASHER-TOP LOADING
Maytag LAT9593AAW WASHER-TOP LOADING
Maytag LAT9593ABL WASHER-TOP LOADING
Maytag LAT9593ABW WASHER-TOP LOADING
Maytag LAT9600AAL WASHER-TOP LOADING
Maytag LAT9600AAW WASHER-TOP LOADING
Maytag LAT9600ABL WASHER-TOP LOADING
Maytag LAT9600ABW WASHER-TOP LOADING
Maytag LAT9604AAE WASHER-TOP LOADING
Maytag LAT9604AAL WASHER-TOP LOADING
Maytag LAT9604AAM WASHER-TOP LOADING
Maytag LAT9604ABE WASHER-TOP LOADING
Maytag LAT9605AAE WASHER-TOP LOADING
Maytag LAT9605AAM WASHER-TOP LOADING
Maytag LAT9606AAE WASHER-TOP LOADING
Maytag LAT9606AAM WASHER-TOP LOADING
Maytag LAT9606ABE WASHER-TOP LOADING
Maytag LAT9606ABM WASHER-TOP LOADING
Admiral LAT9606AGE WASHER-TOP LOADING
Admiral LAT9606BGE WASHER-TOP LOADING
Admiral LAT9606GGE WASHER-TOP LOADING
Maytag LAT9614AAE WASHER-TOP LOADING
Maytag LAT9614AAL WASHER-TOP LOADING
Maytag LAT9614AAM WASHER-TOP LOADING
Maytag LAT9615AAE WASHER-TOP LOADING
Maytag LAT9615AAM WASHER-TOP LOADING
Maytag LAT9616AAE WASHER-TOP LOADING
Maytag LAT9616AAM WASHER-TOP LOADING
Maytag LAT9634AAE WASHER-TOP LOADING
Maytag LAT9634AAL WASHER-TOP LOADING
Maytag LAT9634AAM WASHER-TOP LOADING
Maytag LAT9634ABE WASHER-TOP LOADING
Maytag LAT9635AAE WASHER-TOP LOADING
Maytag LAT9635AAM WASHER-TOP LOADING
Maytag LAT9700AAL WASHER-TOP LOADING
  #2 (permalink)
Old 10-11-2010, 02:43 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
I would remove the top cover of the tub and check for something stuck in there.
If ok, your brakes failed to release. If you turn the tranny pulley in the spin direction and it locks up, you probably need to change the thrust washers and the pulley. Go to www.applianceaid for info on this.
__________________
  #3 (permalink)
Old 10-11-2010, 06:53 AM
Junior Member
Default
Thanks Rich, I love forums good solid info ! Im on snowmobile site too. Good folks out there in cyber space.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Neptune Super Stack will not spin while in spin cycle. Vohn Washer Repair 2 11-04-2010 08:30 AM
motor, belt & trans pully spin, no agitation/spin cycle slavens Washer Repair 2 05-08-2010 04:10 PM
Smoking & No spin Kenmore Laundry Center torino1973 Washer Repair 1 08-27-2009 02:03 PM
Washer will not go through rinse or spin cycle on regular cycle dhilde7165 Washer Repair 0 02-14-2009 04:10 PM
Maytag wash won't spin on regular cycle but will on gentle cycle BlazingSun Washer Repair 0 01-07-2009 08:41 PM
