| » Maytag Washing machine will not spin water out |
Model Number: LAT9700AAW Brand: Maytag Age: More than 10 years
My Maytag washing machine runs great but only a small amount of water slowly drains during the spin cycle. The tub spins and a minimal amount of water drains. Any ideas?
Quote:
Are you missing a small article, sock, napkin, hanky, etc. ? Sounds like something is stuck in the tub to pump hose or pump. Remove the two phillips head screws in the bottom of the front panel,(approximately 3 in. off the floor). Pull out the bottom of the panel, until it unclips itself from the top. Pump and hose are located on the right hand front corner on the base. Drain as much water as possible befor you loosen and disconnect hose clamps. You're going to have water no matter what,but the less you have, the less you need to clean up.
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Maytag washing machine drum does not spin | Bruce Kile | Washer Repair | 8 | 01-17-2011 08:47 AM |
| Maytag Neptune washing machine doesn't spin | Jeneanne | Washer Repair | 14 | 08-16-2010 07:25 AM |
| Maytag washing PAV2300 machine will not agitate BUT will spin | pperovich | Washer Repair | 3 | 08-11-2009 03:11 PM |
| washing machine won't spin the water out it | jgosch | Washer Repair | 1 | 05-10-2009 08:01 AM |
| washing machine won't spin the water out it | jgosch | Washer Repair | 0 | 05-09-2009 12:05 PM |
