When switch is pulled to start no water flows into machine. If I fill the machine manually everything other cycle works fine. (I also fill manually for rinse cycle) Moved water temp switch to hot or cold, no change. I took a guess and ordered an ATC switch.
Any help would be great thanks
M# ATW4475TQ0
