Discuss
Kenmore Washer 1102982 starts cycle by agitating
 in
Washer Repair
My washer started the cycle by agitating instead of filling with water. The water also starts but not to fill.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore Washer 1102982 starts cycle by agitating
  #1 (permalink)
Old 10-05-2010, 08:50 AM
Junior Member
shengnes is on a distinguished road
Default Kenmore Washer 1102982 starts cycle by agitating
Model Number: 11029822801   Brand: Kenmore   Age: Less than 1 year
My washer started the cycle by agitating instead of filling with water. The water also starts but not to fill. I was thinking it was the timer or the electronic control. Does anyone have any ideas? One cycle seems to work correctly, the delicate cycle.
Related Models
Kenmore 11029822801 RESIDENTIAL WASHER
Kenmore 11029832800 WASHER
Kenmore 11029832801 RESIDENTIAL WASHER
Kenmore 11029842990 WASHER
Kenmore 11029842991 AUTOMATIC WASHER
Kenmore 11029852990 AUTOMATIC WASHER-GALAXY
Kenmore 11029852991 AUTOMATIC WASHER
Kenmore 11029852992 AUTOMATIC WASHER
Kenmore 11029882890 AUTOMATIC WASHER
Kenmore 11029882891 AUTOMATIC WASHER
Kenmore 11029884890 AUTOMATIC WASHER
Kenmore 11029884891 AUTOMATIC WASHER
Kenmore 11029892990 AUTOMATIC WASHER-TECH SHEET
Kenmore 11029894990 AUTOMATIC WASHER-TECH SHEET
Kenmore 11029962890 AUTOMATIC WASHER
Kenmore 11029962891 AUTOMATIC WASHER
Kenmore 1103348565 GEARCASE
Kenmore 110357116 GEARCASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110357177 GEARCASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110357970 BASKET DRIVE AND BRAKE ASM
Kenmore 110357972 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110358364 BASKET DRIVE AND BRAKE ASM
Kenmore 110358365 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110358371 GEARCASE AND SUPERSTRUCTURE
Kenmore 110358483 GEARCASE ASM
Kenmore 110358484 GEARCASE AND SUPERSTRUCTURE
Kenmore 110358485 GEARCASE AND SUPERSTRUCTURE
Kenmore 110358487 GEARCASE AND SUPERSTRUCTURE
Kenmore 110358507 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110358795 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110358841 GEARCASE AND SUPERSTRUCTURE
Kenmore 110359175 BASKET DRIVE & BRAKE ASM
Kenmore 110359178 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110359279 GEARCASE PARTS
Kenmore 110359517 BASKET DRIVE AND BRAKE PARTS
Kenmore 110359699 BASKET DRIVE AND BRAKE PARTS
Kenmore 110360093 AMERICAN STANDARD MIXING VALVE ASSEMBLY
Kenmore 110360867 DOLE MIXING VALVE ASSEMBLY
Kenmore 110360868 AMERICAN STANDARD MIXING VALVE ASSEMBLY
Kenmore 110362101 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110362901 GEARCASE ASM
Kenmore 110363000 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110363082 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110364443 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110364444 BASKET DRIVE AND BRAKE PARTS
Kenmore 110364446 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110364494 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365011 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365012 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365014 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365359 GEARCASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365712 GEARCASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365859 GEARCASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110366660 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110366990 BASKET DRIVE & BRAKE ASM
Kenmore 110367551 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110367593 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 1103733107 KENMORE PORTABLE AUTOMATIC WASHER
Kenmore 110389246 GEARCASE PARTS
Briggs & Stratton 110402-0180-E1 ENGINE
Kenmore 11042182200 AUTOMATIC WASHER
Kenmore 11042182201 AUTOMATIC WASHER
Kenmore 11042722200 AUTOMATIC WASHER
Kenmore 11042722201 AUTOMATIC WASHER
Kenmore 11042822200 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11042822201 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042822202 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042822203 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042824200 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11042824201 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042824202 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042824203 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042826200 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11042826201 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042832200 AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 11042832201 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042834200 AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 11042834201 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042836200 AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 11042836201 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042922200 WASHER
Kenmore 11042922201 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042922202 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042922203 RESIDENTIAL WASHER
Kenmore 11042924200 WASHER
Kenmore 11042924201 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042924202 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042924203 RESIDENTIAL WASHER
Kenmore 11042926200 WASHER
Kenmore 11042926201 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042926202 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042926203 RESIDENTIAL WASHER
Kenmore 11042932200 WASHER
Kenmore 11042934200 WASHER
Kenmore 11042936200 WASHER
Kenmore 11043902201 WASHER
Kenmore 11043902202 WASHER
Kenmore 11043902203 WASHER
Kenmore 11044182400 COMPACT WASHER
Kenmore 11044182401 WASHER
Kenmore 11044722400 COMPACT WASHER
Kenmore 11044722401 RESIDENTIAL WASHER
Kenmore 11044826300 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044826301 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044832200 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044832201 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044832202 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044834200 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044834201 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044834202 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044836200 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044836300 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044836301 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044921300 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044921301 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044921302 RESIDENTIAL WASHER
Kenmore 11044931300 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044931301 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044931302 RESIDENTIAL WASHER
Kenmore 11044932200 AUTOMATIC WASHER HORIZONTAL AXIS
  #2 (permalink)
Old 10-05-2010, 02:26 PM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Shengnes,
You most likely have a bad electronic control.
But check for a loose connection at the control and the wire harness down to the flow meter at the fill valve.
If the wiring is OK, replace the electronic control board, mounted on the timer.
(click on part number for more information)
Part number: AP3968899
Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 10-07-2010, 07:26 PM
Junior Member
Default
I replaced the Electronic Control and it is still starting by agitating. Could it be the timer?
  #4 (permalink)
Old 10-08-2010, 08:45 AM
Senior Expert
Default
Shengnes,
Your timer, is the least likeliest of your problem.
Did you check the flow meter and hoses as I reccomended ?
Was the clear plastic tube to the right rear side of the tub OK ?
If all checked OK, this is the part to replace,
Part number: AP4459660
Good Luck,
__________________
Joe M. APP TEAM
  #5 (permalink)
Old 10-10-2010, 05:56 PM
Junior Member
Default
Well I took it all apart and unplugged and replugged everything and shook all the hoses. The hose was on the right side of the tub. and when I put it all together again and started it back up it does seem to work. It must have been one of the connections. I'm running the first load since and seems to be going well. Thanks!!
  #6 (permalink)
Old 10-11-2010, 07:04 AM
Senior Expert
Default
Great,
Hopefully, it was just a loose connection.
If the problem returns, do the same checks you've done ,and replace the switch assembly.
Good Luck,
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
kenmore 80 series washer not agitating david.graham Washer Repair 4 02-26-2010 12:30 PM
Washer not agitating in wash cycle mybrokenwasher Washer Repair 1 10-05-2009 06:38 PM
Kenmore Dryer: starts off hot then cools during cycle 73Ghia Dryer Repair 2 08-21-2009 03:00 AM
Washer starts agitating same time it's filling up hrscales Washer Repair 3 04-03-2009 05:27 PM
washer starts clicking when going to different cycle hotdeal1957 Washer Repair 2 03-20-2008 11:45 PM
