Discuss
1980s whirlpool agitator removal
 in
Washer Repair
washer performs all functions (fill, empties, spins etc) except the agitator doesn't work. seems that the bolt/nut in the middle
Appliance Repair Forum > Appliance Repair Help > Washer Repair » 1980s whirlpool agitator removal
  #1 (permalink)
Old 10-04-2010, 06:20 PM
Junior Member
billhuber is on a distinguished road
Default 1980s whirlpool agitator removal
Model Number: LA5300XKN0   Brand: Whirlpool   Age: More than 10 years
washer performs all functions (fill, empties, spins etc) except the agitator doesn't work. seems that the bolt/nut in the middle is moving, but not the agitator itself. tried to loosen the nut but it moves w/ the bolt - can't loosen of tighten.
any help? this is a belt drive w/ a one-piece "sugrilator" agitator.
thanks in advance!
bill
Ads By Google
Related Models
Whirlpool LA5300XKW0
Whirlpool LA5300XKW1
Whirlpool LA5300XMW0
Whirlpool LA5300XMW1
Whirlpool LA5300XPW0
Whirlpool LA5300XPW1
Whirlpool LA5300XPW2
Whirlpool LA5300XPW3
Whirlpool LA5300XPW4
Whirlpool LA5300XPW5
Whirlpool LA5300XSW0
Whirlpool LA5300XSW1
Whirlpool LA5300XSW2
Whirlpool LA5300XTF1
Whirlpool LA5300XTG1
Whirlpool LA5300XTM1
Whirlpool LA5300XTN1
Whirlpool LA5300XTW0
Whirlpool LA5300XTW1
Whirlpool LA5310XPW0
Whirlpool LA5310XSW0
Whirlpool LA5311XPW3
Whirlpool LA5311XPW4
Whirlpool LA5311XPW5
Whirlpool LA5320XTF0
Whirlpool LA5320XTG0
Whirlpool LA5320XTM0
Whirlpool LA5320XTN0
Whirlpool LA5320XTW0
Whirlpool LA5330XSW0
Whirlpool LA5330XSW1
Whirlpool LA5330XTF0
Whirlpool LA5330XTG0
Whirlpool LA5330XTM0
Whirlpool LA5330XTN0
Whirlpool LA5330XTW0
Whirlpool LA5360XSW0
Whirlpool LA5360XSW1
Whirlpool LA5360XTF0
Whirlpool LA5360XTG0
Whirlpool LA5360XTM0
Whirlpool LA5360XTN0
Whirlpool LA5360XTW0
Whirlpool LA5380XMW0
Whirlpool LA5380XPW0
Whirlpool LA5380XPW1
Whirlpool LA5380XPW2
Whirlpool LA5380XSW0
Whirlpool LA5380XSW1
Whirlpool LA5380XTF0
Whirlpool LA5380XTF1
Whirlpool LA5380XTG0
Whirlpool LA5380XTG1
Whirlpool LA5380XTM0
Whirlpool LA5380XTM1
Whirlpool LA5380XTN0
Whirlpool LA5380XTN1
Whirlpool LA5380XTW0
Whirlpool LA5380XTW1
Whirlpool LA5381XXF0
Whirlpool LA5381XXF1
Whirlpool LA5381XXG0
Whirlpool LA5381XXG1
Whirlpool LA5381XXM0
Whirlpool LA5381XXM1
Whirlpool LA5381XXN0
Whirlpool LA5381XXN1
Whirlpool LA5381XXW0
Whirlpool LA5381XXW1
Whirlpool LA5400XMW0
Whirlpool LA5400XMW1
Whirlpool LA5400XMW2
Whirlpool LA5400XMW3
Whirlpool LA5400XPW0
Whirlpool LA5400XPW1
Whirlpool LA5400XPW3
Whirlpool LA5400XPW5
Whirlpool LA5400XSW0
Whirlpool LA5400XSW1
Whirlpool LA5400XTF0
Whirlpool LA5400XTF1
Whirlpool LA5400XTG0
Whirlpool LA5400XTG1
Whirlpool LA5400XTM0
Whirlpool LA5400XTM1
Whirlpool LA5400XTN0
Whirlpool LA5400XTN1
Whirlpool LA5400XTW0
Whirlpool LA5400XTW1
Whirlpool LA5420XTF0
Whirlpool LA5420XTG0
Whirlpool LA5420XTM0
Whirlpool LA5420XTN0
Whirlpool LA5420XTW0
Whirlpool LA5430XMW0
Whirlpool LA5430XMW1
Whirlpool LA5430XMW2
Whirlpool LA5430XMW3
Whirlpool LA5430XPW0
Whirlpool LA5430XPW1
Whirlpool LA5430XPW3
Whirlpool LA5430XPW5
Whirlpool LA5430XSW0
Whirlpool LA5430XSW1
Whirlpool LA5430XTF0
Whirlpool LA5430XTF1
Whirlpool LA5430XTG0
Whirlpool LA5430XTG1
Whirlpool LA5430XTM0
Whirlpool LA5430XTM1
Whirlpool LA5430XTN0
Whirlpool LA5430XTN1
Whirlpool LA5430XTW0
Whirlpool LA5430XTW1
Whirlpool LA5460XMW0
Whirlpool LA5460XMW1
Whirlpool LA5460XMW2
Whirlpool LA5460XMW3
Whirlpool LA5460XPW0
Whirlpool LA5460XPW1
  #2 (permalink)
Old 10-05-2010, 04:42 PM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
Tilt the washer forward and remove the back panel. With one hand turn the belt, with the other hand, lift up on the inner solenoid plunger till the tranny slide shifts the tranny into agitate mode. Now, you should be able to take the agitator bolt off.
__________________
  #3 (permalink)
Old 10-05-2010, 05:44 PM
Junior Member
Default
thanks for the reply! i didn't do exactly what you said, but i let the machine fill w/a small load of water, got it to agitate mode. the 'nut & bolt' on top of the agitator moved swiftly back and forth. stopped the washer, then tried to loosen the nut. while it gave more resistance than before, it still turned the whole nut/bolt assembly. i tried some wd40 for a couple of hours and even put vice grips on the bolt (yes, hell on the threads). still won't move.
any other suggestions?
tx,
bill
  #4 (permalink)
Old 10-06-2010, 04:33 AM
Senior Expert
APP Volunteer
Default
You run the risk of sheering off the stud if you put too much toque on it. I would bust off the agitator with a wood chisel, then put WD-40 on the exposed stud threads, then torque it back and forth till it comes loose.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Agitator removal / how? sandrafix Washer Repair 2 05-09-2010 05:03 PM
Removal of agitator Jprim Washer Repair 1 03-10-2010 02:34 PM
agitator removal scottlisa Washer Repair 1 10-26-2009 01:14 PM
Agitator Removal awookiecookie Washer Repair 0 02-05-2009 04:11 PM
agitator removal spiderman3d Washer Repair 3 10-17-2008 04:43 AM
