washer was moved from my old house to new one. worked when last tried.. has sat about a year now...i just hooked it up and it does everything but spin..also the tub seems out of kilter..
I cannot get your model number to come up, so I am assuming you have a Whirlpool built direct drive Kit Aid I am thinking you have two problems. The move may have pushed the tub off its base, and may have damaged a support spring. You need to take off the cabinet to check it out. Spin problems are usually associated with a clutch problem. 'see this site for how to check it Clutch Replacement on Whirlpool and Kenmore Washers
