My front load washer will not complete a cycle. I get error messages "sud lock" and F21 which indicates inability to drain. We only use "HE" detergent. I have cleaned the detergent adding section, and have used Tide washer cleanser on the machine. I have removed and cleaned all the drain hoses. There are no kinks anywhere. I have poured water into the detergent adding section and sometimes it works other times it doesn't. I have read the entire manual and did what it suggested and have ended up waiting 24 hours and more with no improvement. What else could be causing this problem?
